Electric vs. Belt driven fans!!! - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Electric vs. Belt driven fans!!!
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-17-2010, 12:35 PM   #91
DavidAnderson
do they make a solid fan mount, no clutch. Thats my only problem, water crossings tear up the clutch. for a tj
DavidAnderson is offline   Reply With Quote
Unread 07-17-2010, 01:00 PM   #92
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Then you may propeller the fan blades into the radiator...
Knuckelhead is online now   Reply With Quote
Unread 07-17-2010, 01:04 PM   #93
TeeJay00
TeeJay00 is offline   Reply With Quote
Unread 07-17-2010, 01:44 PM   #94
biffgnar
biffgnar's Avatar
Originally Posted by TeeJay00 View Post
Yet somehow WJ's don't have the same overheating problem as TJ's !!!
Has it been established that TJ's have an overheating problem? I readily acknowledge that you are in an environment that makes it more challenging then mine, but a few posts on JF does not make an epidemic. Think about how many TJs there are in the world functioning with stock setup and no problem (mine included). JF is a small fraction of the world of TJ owners and people generally only create threads if they have a problem. Would be pretty boring if all the people with no problems started threads to tell us that. The negative selection of what threads are started leads to a perception of too many "common" problems.
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is offline   Reply With Quote
Unread 07-17-2010, 02:57 PM   #95
mrblaine
mrblaine's Avatar
I know of a few problematic TJ's with overheating issues and by and large, no amount of money, gadgets, high dollar external coolers, and very expensive radiators have solved the problem to better than another stock system.
I've related the story of my wife's rig too many times, but after the CSF fiasco and a bit of research and not too much at that, I swapped back in the stock 1 row from the dealer, found a good friend willing to trade me a 7 blade fan and HD clutch and it's cooling is rock solid at any speed on the freeway with the AC on full blast. And, it is an auto with a very small cooler for the radiator in the grill area.
The thermometer on the mirror display was 107°F earlier this week and it's been consistently over 104.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 07-17-2010, 03:10 PM   #96
Knuckelhead
AFSOC Retired
Too bad DC discontinued the TSB 7 blade fan. It was one of the best modifications they came out with...
Unread 07-17-2010, 03:40 PM   #97
TeeJay00
Did it really have such a noticeable effect??
Unread 07-17-2010, 04:28 PM   #98
sportcoupe
I switched to a Taurus 2-speed electric fan last winter and now that the summer heat is here I am putting the stock clutch fan back on because the electric fan just doesn't cool as well during slow trail riding and extended highway speeds during the summer here in Georgia heat.
My Taurus 2-speed electric fan conversion (complete with wire harness, factory relays, adj thermostat, 3-way guarded switch and indicator lights) is for sale here:
http://www.jeepforum.com/forum/f128/...up-tj-1071183/
sportcoupe is offline   Reply With Quote
Unread 07-17-2010, 05:44 PM   #99
Knuckelhead
AFSOC Retired
I've done a bit of work with the 4.0L on 2000+ TJ's and yes, the TSB 7 blade fan and fan clutch made a significant improvement with cooling...
Unread 07-17-2010, 05:49 PM   #100
TeeJay00
So there is no way of getting those parts anywhere anymore???
Unread 07-17-2010, 06:17 PM   #101
Knuckelhead
AFSOC Retired
You can get the TSB fan clutch, but not the 7 blade fan. If you find a source for the 7 blade fan, please let me know?...
Unread 07-17-2010, 06:35 PM   #102
mrblaine
mrblaine's Avatar
Yes, it's makes that much difference.
I am Savvy
Unread 07-17-2010, 07:01 PM   #103
Knuckelhead
AFSOC Retired
Ya know, if someone were to make a fan and clutch that.......
Never mind...
Unread 07-17-2010, 08:15 PM   #104
jmpowie
Originally Posted by ageorgakis View Post
You removed the stock fan shroud, installed the taurus fan without a shroud and got better cooling??? Have you tried pushing your engine for a few minutes at high RPM?
Do you understand why there is a big shround on a belt driven fan? Its because the fan is so far away from the rad you would get no air pulled throw the rad. When you mount a electric fan you mount it to the rad not the engine. So you dont need a big shroud. I think one of the reasons there is so many people who say electric fans are bad is because they dont understand them.
jmpowie is offline   Reply With Quote
Unread 07-17-2010, 08:19 PM   #105
mrblaine
mrblaine's Avatar
Within reason, the depth of the fan shroud will not change the amount of air through the radiator provided it is contructed properly.
I think you need a better understanding of how air flows, but you could always learn some by removing the shroud from your electric and report back.
I am Savvy
tj , wrangler , fan , electric , belt , driven , comparison , difference , advantage
