Quantcast Electric swaybar disconnects - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Electric swaybar disconnects
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 07-14-2005, 07:48 PM   #1
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Has anyone seen any write ups on installing electric swaybar disconnects like the new Dodge Powerwagon has into a wrangler. I thought AEV had done this mod but can't seem to find any info on it. I even emailed them about it with no response. If any vehicle should be so equipt it should be a Jeep. Is the part available throught Chrysler yet.
Reelm n Rubi is offline   Reply With Quote
Old 07-14-2005, 08:23 PM   #2
Oman Jeep
The only thing close is the OffRoadOnly SwayLoc.
It's a dual-rate air-pressure controlled Swaybar. You can choose between stiff for on-road (like stock) and soft for off-road (like an AntiRock) at the touch of a button, giving you the best of both worlds and no grease or dirt on your hands
Oman Jeep is offline   Reply With Quote
Old 07-14-2005, 10:11 PM   #3
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
... and I sooooo want one :P~~
I need a 35" tire for spare. PM me if you have something.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
Old 07-14-2005, 11:05 PM   #4
Oman Jeep
Same here ... Emptying every pocket and it's not enough!
Old 07-14-2005, 11:09 PM   #5
0IIII0
Just somehting else to break!
[b]SURGEON GENERAL'S WARNING[/b]
Books may introduce unfamiliar or confusing ideas.
In the event of uncomfortable self-reflection,
heat to 451° Fahrenheit and seek television immediately.
"Every argument has a motive, but only the arguments given matter."
[COLOR=SandyBrown]Khaki[/COLOR] Jeep Club Member #[B]28[/B]
Jeep Sahara Club #70
0IIII0 is offline   Reply With Quote
Old 07-14-2005, 11:29 PM   #6
Reelm n Rubi
Fish fear me
I think I'll put one on my wish list. Thanks for the replies.
Old 07-14-2005, 11:45 PM   #7
Oman Jeep
Actually it's fail-safe. If you lose your air supply it will spring back to the street position.
If you carry some basic equipment to repair air-lines or whatever you could even rig it up to be powered by your spare tire.
ORO is a company that makes a complete air-bag suspension system which has had excellent reliability to date. I have no hesitation running their equipment and the only thing holding me back is the price and other stuff the Jeep really needs (trackbar, tires etc...)
Old 07-15-2005, 12:08 AM   #8
Stu Olson
Stu Olson's Avatar
Yep, sure is.....just like those little air compressors and air lockers in your Rubi.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 07-15-2005, 12:10 AM   #9
Oman Jeep
Good call
Is the Rubi compressor powerful enough to activate the SwayLoc system? I'm not sure on that one...
Old 07-15-2005, 06:05 AM   #10
neZZr
neZZr's Avatar
Good call
I don't believe so. The Rubi lockers only requires something like 7-8psi IIRC.
SIRA 4x4 club
Old 07-15-2005, 06:53 AM   #11
Oman Jeep
Yeah I'm not sure what SwayLoc needs. Apparently it can be done from the spare tire which at most would be 33 psi... so maybe it will run on less.
It's possible but I have no clue to be honest.
Old 07-15-2005, 08:26 AM   #12
Reelm n Rubi
Fish fear me
from what I was reading they need about 70 psi but they said the can operate at less. The rubicon compressors are low pressure, 6-8 psi. They had the swayloc system listed at $600 at their site. I think I read there was a manually activated system that uses a hand pin instead of air pin.
Old 07-15-2005, 08:34 AM   #13
mrblaine
Brake Wizard
mrblaine's Avatar
There is not a hand operated system yet. What the "manual" part means is that you flip the switch to send air to the actuator instead of the On Board computer used with their air suspension. The computer automatically controls the Swaylok depending on what mode you are in.
mrblaine is offline   Reply With Quote
Old 07-15-2005, 08:53 AM   #14
Oman Jeep
Exactly, which is why the pricing is identical between the two options. If it was hand-operated, you would expect it to be cheaper. In one version you get an AiRock wiring harness, in the other you get a switch.
It's also possible to get the "manual" switch operated one and later make it AiRock integrated, which is the course I plan to follow, as with our weather and my larger bumper I don't like messing around with those disconnects at all...
Anyway sounds like the Rubi compressor is out, but if you have ARB lockers, the ARB compressor should easily be up to the task. Or you could just have a pressurised tank filled the same way as your tires.
Old 07-15-2005, 10:45 AM   #15
cincytj
seems like you could figure out a way to modify the swaylock air selenoid to an electric one if you had to have it electric.
[COLOR=Navy][SIZE=2]03 Patriot Blue Sport[/SIZE][/COLOR]
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline   Reply With Quote
Glock Forum
