electric interference - JeepForum.com
post #1 of 7 Old 03-01-2007, 02:47 PM Thread Starter
rinterr
i have two tens wired in the back of my tj and i noticed an odd high pitched buzz coming from them today when they have power but the music is turned all the way down. my guess is some sort of interference from the engine, but i was wondering if its the power cable or the RCAs that would recieve the interference. Thanks for the help.
black, spice top, or camo bikini :), 33" open county m/ts, lots of stupid toys
rinterr is offline
post #2 of 7 Old 03-01-2007, 02:58 PM
TheFredElement
How is it grounded? Always make sure you use a clean ground. It can be the RCAs, I notice when routing RCAs behind the HVAC (and depending on their on/off position) sometimes they pick up some interference. If you're sure you have a clean ground and have no other way to run the RCAs you can pick up some GLI (ground loop isolaters). However re-routing the RCAs / clean ground - would be way cheaper.
TheFredElement is offline
post #3 of 7 Old 03-01-2007, 02:59 PM
mdm
Farm Wheeler
Do you get it when you turn the key on without starting the engine and then it will stop after a few seconds?
mdm is offline
post #4 of 7 Old 03-01-2007, 03:18 PM
Jackle
you should also run your power wire on a seperate side of the vehicle as the RCA's....running them next to each other can cause interference
Jackle is offline
post #5 of 7 Old 03-01-2007, 03:56 PM
yellowismellow
Custom User Title
yellowismellow's Avatar
run your power wires on one side, and the rca's on the other side. avoid the middle of the floorpan cuz that will cause a worse noise.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #6 of 7 Old 03-01-2007, 08:00 PM Thread Starter
rinterr
well ive got my power on the drivers side and the RCAs running up the middle, i dont think its the ground, im using the bolt under the backseat, i think one of my RCAs is the problem, now that i think about it the noise started after i had to replace, ill go tomorrow and buy a better quality RCA and see if that fixes it
rinterr is offline
post #7 of 7 Old 03-01-2007, 08:03 PM
Rocky529
Rocky529's Avatar
Route the RCAs on the passenger side and run it behind your dash to your headunit.
I have power on passenger side (saved me from running power across the firewall in the engine compartment), and have RCAs on driver's side. No issues at all with my 10" DVQ.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
MyGig - AM Interference spolebitski JK Wrangler Technical Forum 0 04-16-2009 08:39 PM
OME Spring Interference brvoyles TJ Wrangler Technical Forum 3 08-01-2008 11:31 PM
Is the 4.2 an interference motor? Rebel442 YJ Wrangler Technical Forum 17 07-18-2008 05:58 AM
Radio Interference bob082484 YJ Wrangler Technical Forum 1 01-24-2008 10:53 AM
Driveshaft Interference jedi11 TJ Wrangler Technical Forum 5 02-02-2003 10:35 AM
