Electric Fan Conversion and HP Gains... - JeepForum.com
 1Likes
post #1 of 261 Old 12-11-2005, 07:35 PM Thread Starter
loudog3114
Has anyone converted to an electric fan and gained noticable horse power? Also, when you did the conversion, how did you then route the belt if it was an I6?
92 YJ, 35's, 6", Locked
97 Honda CBR1100xx
08 336XI
loudog3114 is offline
post #2 of 261 Old 12-11-2005, 07:40 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It won't be noticeable since the alternator then has to work harder to produce the electricity that the new electric fan draws... and the more drain on an alternator, the harder it is to turn. In other words, there is no free lunch where energy production is concerned.
Jerry Bransford is offline
post #3 of 261 Old 12-11-2005, 10:04 PM
Stu Olson
Stu Olson's Avatar
Couldn't you just put the nuts back on the pulley and run it like that? Here is a photo of a '99 TJ with the fan removed. I've not tried it myself but it seems likely it would work.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 261 Old 12-11-2005, 10:21 PM
FifteenCents
I agree that the reason is not to gain horsepower. horsepower is not what jeepers are conserned about...TORQUE is the key, and an electirc fan will not help there. BUT it will help in deep water as you can turn it off so it won't munch your radiator with the water causes the fan to pull forward and chew up your radiator.
The pulley is held on by four studs that are run into the water pump and the fan is held on to them by nuts...just back out the studs and put in shorter bolts in their place....
SO...to recap..if you do not have a snorkel don't waste your time or money on an electric fan you will have to upgrade your electrical system.
New Bigger Alternator $$$$
Electric Fan $$$$$$
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #5 of 261 Old 12-12-2005, 02:00 PM
jbrnigan
Jerry's response is accurate as far as it goes. Yes it will take additional horses to turn the alternator when the electric fan is running, but you will achieve a noticeable gain when the fan is static, which should be most of the time that the Jeep is moving - street time. Slow off road and stop and go will cost you horses. Many electric fans can be pre set to turn on from between 180 and 200 coolant degrees measured at either at the upper radiator hose or via a probe in the readitor near the upper hose connection. They can also be manually cycled.
Silver,'04 Sport, 4.0L, 5sp, D30/D44 tracloc,
3.73, F&R disc, 30x9.50, every available factory option, Bilsteins, Hella, Hurst, KC, K&N,
RCI Racing, Ram Off Road, Roadmaster tow bar.
jbrnigan is offline
post #6 of 261 Old 12-12-2005, 02:14 PM
o2tj
o2tj's Avatar
lol! you guys need to try a ford two speed and tell me you have no gain in power. also you have no rotating mass....have you guys felt how heavy a fan and clutch are. you will also have longer w/p life. my fan stays off most of the time even in the summer it only comes on for about 3-4 min wile sitting in traffic. off road it cycles but most of the time Im in low anyway and the rpm are up. You should have a mean green alt anyway if you plan on a winch w/ lights and stero....you cant tell me you dont have that stuff .................................................. .....OH! just to let you know my fan on high only draws 21 amps and low is a low 9 amps wich I use on the street.
o2tj is offline
post #7 of 261 Old 12-12-2005, 02:23 PM
TenaciousTJ
Are you running the Taurus, spelling is probably all messed up, dual fans? If so, pics would be excellent and much appreciated. Do you think they would work in an '05?
2005 Black 'Con. The goods:37"SSR's-15x10 M/T's-RE LA 5.5"w/ 7.5"springs-JKS 1.25"BL-M.O.R.E. 1"MML-Alloy 5.13 gears-PSC HD steering-PSC rockrings F/R-PSC rockers w/ slider bars-OMF rock domes-Pro Fit VSM-Hanson 52" rubicon bumper-JKS BPE's-Power windows-Husky liners-Alloy tube seals-AEM intake-Poweraid TBS-Banks header and cat back w/ monster muffler-empty pockets.
-OlllllllO- Life is Good
TenaciousTJ is offline
post #8 of 261 Old 12-12-2005, 02:43 PM
jeeptj19992001
the belt would stay the same, you still need your water pump...or am i missing something?
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #9 of 261 Old 12-12-2005, 02:59 PM
o2tj
o2tj's Avatar
Ill take som pics tomorrow and post them........as long as its not iceing tomorrow. an 05 ......Oh yeah! easy
o2tj is offline
post #10 of 261 Old 12-12-2005, 04:22 PM
Hunter9
Hunter9's Avatar
A water pump by itself does not take much energy to run, but o2tj is right the rotating mass is there, like the difference between a axle turning with and w/o a wheel and tire attached.
On the other hand Jerry is correct the amount of usable HP and/or torque is in such a small amount it is probably not worth the extra $$$ to do it, unless you are trying to gain the ability to turn off the fan.
97 Sport 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
Former 3.07 Gears Club Member #1
Hunter9 is offline
post #11 of 261 Old 12-12-2005, 04:41 PM Thread Starter
loudog3114
are you guys referring to using a ford taurus electric fan? if so is there a write up somewhere?
97 Honda CBR1100xx
08 336XI
post #12 of 261 Old 12-12-2005, 04:45 PM
Steve B
Steve B's Avatar
A water pump does take a lot of energy to run, I work for a reputable engine tuner in the uk and on a 2.0litre 4cylinder petrol making the water pump pulley larger and slowing the pump down gained 15bhp......
MY JEEP IS A 1999 4.0 SPORT
Steve B is offline
post #13 of 261 Old 12-12-2005, 05:03 PM
Tj4rocks
I have converted mine to electric fan about 3 years ago. As far as the water pump, i just took off the fan and put the nuts back on. As far as a power increase, i could tell a difference cruising down the highway because the electric isn't pushing around air it doesn't need to. I am happy overall that i did this mod to the jeep. I'm using the flex-a-lite black magic fan. I haven't noticed any problems with the charging system and don't see any reason for a bigger alternator. Just my 2 cents.
97 TJ Sport 5 speed
4 inch teraflex
33x12.50 trxus
Tj4rocks is offline
post #14 of 261 Old 12-12-2005, 06:31 PM
drottie
I'm also running a Flex-a-lite Electric. I didn't notice any huge HP/torque/ whatever gains. I did notice that you can dial in the cooling, IE warmer in winter, cooler in summer if that's a biggie for you. I also noticed this thing is LOUD. Kinda weird I wired mine direct (no I haven't had any problems with it running the battery down) and it'll cycle on and off a couple of times after the jeep's been turned off. I did have my Jeep start running hot on a trailride this summer, but we were pounding on them pretty hard and there were jeeps with mechanical fans that were also running hot on the same runs. In retrospect I could have spent the money elsewhere..... my.02
1999 Jeep TJ .....pretty far gone from stock
drottie is offline
post #15 of 261 Old 12-12-2005, 08:56 PM
StealthTJ
<SNIP>
The fan should make no difference at all since you're running up against the thermostat anyway.
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
electric fan conversion laybackman YJ Wrangler Technical Forum 7 09-07-2014 10:59 AM
Electric Fan Conversion JSBlu974X4 TJ Wrangler Technical Forum 52 01-22-2011 07:28 PM
electric fan conversion? DominicVan91 YJ Wrangler Technical Forum 32 12-02-2009 04:48 PM
Electric fan conversion bryans98tj TJ Wrangler Technical Forum 8 12-23-2006 12:30 AM
