Ehhh, shouldn't this be connected? - JeepForum.com
post #1 of 8 Old 03-22-2010, 08:55 PM Thread Starter
ChemESGH
Just got a 97 SE this past weekend. Been looking it over and getting familiar with it (changed out ignition switch, oil change and air filter change today). As I was adding new oil from the aforementioned oil change I found this unconnected wire:
Any help figuring this one out? I appreciate it!
ChemESGH is offline
post #2 of 8 Old 03-22-2010, 10:46 PM
2ACR
That's Right I Support
2ACR's Avatar
Do you have AC? I have a 97 that had the AC pulled out. There are two or three wires for the compressor and such. That looks like the right spot for the AC. If you don't have AC there will be a u shaped deck right under that wire with threaded holes on each corner.
If I remember correctly I have another one near the block on the same side that is not connected to anything.
Those wires don't bother me any more. The ones that bother me are the three wires I found disconnected under the driver side dash. One is by the OBD2 and the others follow the ignition wires.
Originally Posted by jr03 View Post
And when you can't find the wrench your holding in your hand, it's time for a break:rofl:
Jeep Jedi in Training.
2ACR is offline
post #3 of 8 Old 03-22-2010, 10:47 PM
Lynch_6913
I could be wrong but it seems to look like a sensor plug, are all your gauges working properly? its near where the oil pressure gauge sensor is located, (next to oil filter...) or do you have any after market gauges installed?
Lynch_6913 is offline
post #4 of 8 Old 03-22-2010, 10:51 PM
spdnjoe
I could be wrong also, but to me it looks like the plug that goes to the under hood light. I don't see any wires in the pic going to the hood.
D DING DING or bbbbuuuuzzzeeerrrr ?
spdnjoe is offline
post #5 of 8 Old 03-22-2010, 11:44 PM
2ACR
2ACR's Avatar
I think spdnjoe may be right if I am not. I didn't really notice where the wire was coming from. I noticed its general location.
The hood light branches off those main lines running from left to right. One should go up and on to the hood.
2ACR is offline
post #6 of 8 Old 03-23-2010, 12:26 AM
element54
element54's Avatar
Hood light
Why is there so much space down here?
element54 is offline
post #7 of 8 Old 03-23-2010, 04:24 AM Thread Starter
ChemESGH
Man that hood light would have been nice when changing the oil last night. Awesome, I appreciate everyone's help!
ChemESGH is offline
post #8 of 8 Old 03-23-2010, 06:22 AM
Lynch_6913
Damn Spdnjoe after i read yours i figured you had it... but i didn't say nothing, had to hold onto the last sliver of hope.
connector , engine , jeep , unknown , wire
What is this suppose to be connected to? medicbear YJ Wrangler Technical Forum 16 06-08-2008 08:36 PM
What is this, and should it be connected? hbmex858 YJ Wrangler Technical Forum 4 05-17-2007 05:28 PM
How Do You Have Your CB Ant Connected? NIUPonyBoy YJ Wrangler Technical Forum 10 03-20-2006 05:53 PM
Ehhh... starting.... grrr.... *quick help please* lordmatt YJ Wrangler Technical Forum 9 01-03-2005 10:19 PM
Not Connected vader TJ Wrangler Technical Forum 4 12-11-2004 03:42 PM
