EGR valve on TJ? - JeepForum.com
post #1 of 5 Old 07-01-2004, 07:14 AM Thread Starter
cygnus3978
cygnus3978's Avatar
EGR valve on TJ?
I had a friend fail inspection on her car(95 camaro), specifically the NO part and the shops replaced the EGR valve(Exhaust Gas Recirculation).
I had never heard of this before so I researched it and found that it acutally takes exhaust gasses and re-inserts them into the cylinders to lower the burning temperature and help the NO pass through the system unburned and prevent it from picking up other atoms and becoming smog...basically.
The science I have may be a little off, but the principle is the same.
Well I got to thinking about where the TJ EGR valve is....and I CAN'T find it on my jeep or in the FSM for that matter as well.
DO TJ's have an EGR valve? If so where...and if not, what do we use in place of the EGR.
'97 TJ SE...yeah yeah I know, it's a 4 banger.
2.5L HIGH OUTPUT BABY!!!
cygnus3978 is offline
post #2 of 5 Old 07-01-2004, 07:32 AM
AjRagno
I don't think it does.
I had one on my F-150, which was problematic because it sent so much gunk into the intake manifold, but can't find it on the 4.0L or in the manual. Either we don't need it or DC decided to allow the cats to do their job and clog sooner.
AjRagno is offline
post #3 of 5 Old 07-01-2004, 07:58 AM Thread Starter
cygnus3978
cygnus3978's Avatar
Well Cat converters only take care of hydro carbons, not the Nitric Oxide. Unless DC found a way to lower combustion chamber temps without an EGR valve the Cat would do nothing with this process.
post #4 of 5 Old 07-01-2004, 08:22 AM
AjRagno
My point is that all of the carbon build up I found in the intake manifold of my F-150's engine needs to go somewhere if the EGR is not redirecting this back into the engine. If these gases do not go through an EGR system, then they are definitely going into the cats and collecting there.
AjRagno is offline
post #5 of 5 Old 07-01-2004, 12:08 PM
Pakrjeep
Pakrjeep's Avatar
That's not totally right--the catalytic converter, if it is a 3 way cat, it absolutely helps eliminate NOx. In fact, the TWC is the most efficient method for getting rid of NOx emissions. If the test failed on NOx, then it can ONLY be the Cat converter or the EGR. No other emissions systems on a vehicle really help with NOx other than those two.
'99 2.4L TJ "Gone"
'03 4.0L TJ "Gone"
'06 "Jeep Green" Rubicon
Air Force Jeep Club Member # 2
Pakrjeep is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-29-2012 12:07 AM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
EGR valve help cableguy01960 YJ Wrangler Technical Forum 1 10-28-2008 10:20 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 04:33 PM
pcv valve? genakab TJ Wrangler Technical Forum 6 02-24-2006 08:05 AM
