The effect of steering stabilizer on death wobble - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > The effect of steering stabilizer on death wobble
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 08-16-2012, 09:56 AM   #1
vettefever5
So here's my death wobble story and my question.
I finally got my 2.5" suspension installed over the weekend. I didn't have time after I finished to align the front tires so I figured I'd just drive to/from work and do it when I got home. Well, on the way to work I hit a bump around 40mph and I got a slight shimmy in the steering wheel... nothing like I had felt before. I had a feeling it was DW, even though it went away quickly (I was already slowing down). On the way home I made a point to drive down a long straight road with a 55mph speed limit that I know is very bumpy. If I could make it down there without problems I figured I'd be good. As soon as I hit the first bump (around 45mph) DW hit, and it scared the @#$@& out of me, even though I was expecting it. I quickly pulled over, caught my breath, and drove home slowly.
I checked all the stuff in the steering... I tightened the track bar at the axle (even though it was already very tight) and noticed the tie rod at the pitman arm had a rip in the boot. I was going to bring it in for an alignment anyway so I figured I'd replace that at the same time. I measured the toe in of the front tires and I was about 1" closer in the front, which I know is WAYY off. I know I can do the alignment myself, but after feeling the effect of DW I'd rather have a shop do it, then check the measurements against what's recommended on here before I try it myself in the future.
With that said, I know that may or may not get rid of DW, but I need to start with what I know is worn. Even if this does fix it I'm always going to be nervous driving down the highway that something like that might happen again the next time a steering component wears out.
My question is.... if I get a heavy duty steering stabilizer, will that help minimize the effects if/when DW rears its ugly head again? I know it won't eliminate it, but if it would help control the vibrations so that I feel like I can pull over safely and change my pants then it's worth it to me.
Any thoughts/experiences?
Thanks in advance
vettefever5 is offline   Reply With Quote
Unread 08-16-2012, 10:06 AM   #2
Shobes
Innovating Failure
When I did a 4" lift awhile back my cast was way off which caused the death wobble. Replacing my stock front lower control arms with longer aftermarket versions rid me of my issues. If I had to do it over I would have gotten Rokmen adjustable CAs which I am planning to do soon.
The stabilizer will help bump steer And should be upgraded if you go to a larger then stock tire size but it's not going to cure death wobble.
Just my .02. Good luck!
Shobes is offline   Reply With Quote
Unread 08-16-2012, 10:21 AM   #3
herklord
^^^ I agree a steering stabilizer is a band aid not a cure. Cures include track bar, tie rod and drag link ends, alignment and a whole host of other causes of which steering stabilizer is not one. Find the problem not the temporary fix
04 TJ Willys Edition 4.0 five speed, metal cloak front, groundpounder rear, zj tie rod, currie track bar, more to come
herklord is offline   Reply With Quote
Unread 08-16-2012, 10:34 AM   #4
DBLJ
DBLJ's Avatar
Thanks in advance
No. It will not fix anything. Check every front end component. Track bar, ball joints, control arms/bushings, wheel bearings. Everything.
Buy my welder. http://www.jeepforum.com/forum/f94/l...75-hd-1399807/
DBLJ is offline   Reply With Quote
Unread 08-16-2012, 01:39 PM   #5
vettefever5
Thanks for the replies.... but I may have been a little unclear in my question.
I have read lots and lots about how to fix/troubleshoot DW, so I'm not going to raise that question again (yet).
My question is about AFTER I get it fixed (thinking positively). If DW is caused by sloppy or warn steering components, unless I replace EVERYTHING at once, odds are something will eventually wear out next and give me DW again.
So, in the future... if I get everything tight and I have no DW, THEN add a steering stabilizer, IF DW comes back again will the SS dampen the effect of it until I can get it actually fixed again (not relying on the SS as the fix)?
Once I get it fixed and I have no death wobble, I don't want to be surprised by it again in the future like I was this time. If it comes back I want the effect to be not quite as dramatic. I'd hate to be driving around the windy mountain roads in NH only to have DW so bad that I'd be in danger of driving off the edge.
Unread 08-16-2012, 01:52 PM   #6
biffgnar
biffgnar's Avatar
If you are paying attention you should feel steering shimmy start to develop even with an SS installed long before it gets to the oh crap DW state.
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is offline   Reply With Quote
Unread 08-16-2012, 02:04 PM   #7
YogiBear88
you may have slung a weight... happened to me. had DW really bad. used to go crazy even on the smallest bumps. go get your tires balanced.
YogiBear88 is offline   Reply With Quote
Unread 08-16-2012, 02:46 PM   #8
BioTex
OIIIIO
BioTex's Avatar
Of course a new steering stabilizer will help with DW. Chrysler says so!
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote
Unread 08-16-2012, 03:13 PM   #9
willydigger
Thanks for the Upgrade!
willydigger's Avatar
+1. I think you'll get some warning.
Your alignment was likely your problem if it was 1 inch off.
In my experience, all of my DW's have given be some notice with the exception of my initial installation (no alignment) and my first self alignment (I adjusted a little to far in). Both caused immediate DW.
My other cases typically related to tire balance. With those I've always had some type of indicator.
I've come to the conclusion that there will always be a chance of DW with the Jeep.
A lot of people will say get a steering stabilizer. I've heard it from shop owners and dealers. It will do nothing for you.
WHODEY
willydigger is offline   Reply With Quote
Unread 08-16-2012, 03:56 PM   #10
RowJ
RowJ's Avatar
There is your answer!
Pay attention and solve any minor vibrations and the big one will never show up!
RJ
98 TJ w/ 4.0L, 5 speed, 4" lift, 1.25" BL, 4.56 gears, Lockers, T.T., 33" Cooper STT's.
2002 Dodge Diesel 2500, Ext Cab/Long Bed, 602 HP/1244 Ft-Lbs
RowJ is offline   Reply With Quote
Unread 08-17-2012, 06:01 PM   #11
9703tj
Out of ballance tires are a DW trigger, but they're not the cause. The cause is something in the front end is worn out and isn't holding the front axle/steering nice and tight like it should be. If all of the front end components are good and tight you could have no wheel weights at all, and a big clump of dried up mud on the inside of each rim, and still not get DW, you'd just have a shakey ride.
9703tj is offline   Reply With Quote
Unread 08-18-2012, 09:15 AM   #12
herklord
^^* I agree in my limited experience the "ovaling" if you will of the track bar mounting holes is the most common cause. As time goes on the bolts holding the track bar slowly wear a bigger hole in the frame or drag link/tie rod. Currie track bar uses oversize bolts requiring drilling which may help in this case
Unread 08-18-2012, 11:26 AM   #13
skrap1r0n
No, it won't. How do I know? I just did it. I replaced all 4 shocks and SS, had tired rotated and balanced. And it is actually worse. I am in the process of checking everything else now.
Save your money till you know what it is. I wish I had, but I didn't come here before buying the shocks.
skrap1r0n is offline   Reply With Quote
Unread 08-18-2012, 12:51 PM   #14
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Caution that not many tire shops will take the trouble to get tires perfectly balanced. On a TJ, the bigger the tire, the more important perfect tire balance is. My local Discount Tire store is, generally speaking, superb on getting my tires balanced properly the first time. But I have had to go back multiple times in one day at least three times over the years when the tech rushed the job and didn't get them balanced well enough.
In other words, having the tires balanced doesn't necessarily mean they were balanced well enough.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 08-18-2012, 01:28 PM   #15
flying_bosun
Originally Posted by Shobes
When I did a 4" lift awhile back my cast was way off which caused the death wobble. Replacing my stock front lower control arms with longer aftermarket versions rid me of my issues...
The stabilizer will help bump steer And should be upgraded if you go to a larger then stock tire.
I'm a bit late to the party, but chiming in to say that's good feedback on the LCAs. Im also surprised that no one stepped up to mention that bumpsteer is in no way related to or affected by a steering stabilizer or lack thereof.
Gear-Calculator Stu Can Help You Part Names and Numbers Dealer Supplied Parts and ask for "Jeep Club" Prices
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline   Reply With Quote
