ECM reflash... - JeepForum.com
post #1 of 8 Old 10-10-2006, 09:13 PM Thread Starter
cj7guy
ECM reflash...
Does anyone do this for the 4.0s? I know a lot of cars stand to gain a good bit of power and often fuel economy by a few changes to the tune.
The turbo kits that I've seen for the 4.0 seem to come with a gay FMU which isn't the best way to adjust fuel.
I was just checking this forum to see if anyone knows of a good place to get an ECM reflashed.
I do have an XJ, but the TJs are definitely the most popular Jeep to modify that's on the road today. Not to mention, there is a much smaller group of XJ guys who interested in expensive mods.
Let me know,
Thanks,
Jon
07 JKU - 6spd - LSD rear
cj7guy is offline
post #2 of 8 Old 10-10-2006, 09:42 PM
dyna
Ive never heard of reflashing the ecm with a laptop or?. Adding a chip or other goodies then clearing it to allow time to learn new info and adjust to the new equpt.
dyna is offline
post #3 of 8 Old 10-10-2006, 10:01 PM Thread Starter
cj7guy
This isn't something you can do in your garage. Someone with the right equipment can do it. It's much more common with performance engines (Evo, STI, GM V8s). Tuners just reflash the ECM with new settings, rather than messing around with 100 different add-ons that attempt to trick the ECM.
cj7guy is offline
post #4 of 8 Old 10-10-2006, 10:02 PM
dougolupski
It's Heep not Jeep
There is no need to get a reflash on a TJ. We don't have a mass air sensor so the feflash doesn't work the same for use as it does with other cars and trucks. The only time I have heard of someone mess with there ecu was Jason at Redrock 4x4. He did it for his turbo kit that he had in there. Email or call him if you want more info on it.
Jeep: 07 Wrangler X 2DR Black
Crime Guard Alarm with 2way pager, AFE CAI, DynaPro Exhuast
M.O.R.E. Body Lift, Source Co2 Tank, Stubbied Stock Front Bumper
KMC XD 795 Hoss Black 17" wheels and Maxxis Bighorn 305/70/17 tires
Every mod in the write up section.
Old Jeep: 04 Wrangler X Yellow Built To The Hilt For Three Great Years.
POLISH JEEP OWNERS CLUB #2
dougolupski is offline
post #5 of 8 Old 10-11-2006, 05:55 AM Thread Starter
cj7guy
Why would we need a MAF to get gains from more efficient engine settings? Are you saying the 4.0 comes from the factory with the best power and fuel economy possible? That would be pretty amazing, generally speaking, mfgs build a margin for error into the vehicle's settings so that people who don't keep up proper maintenance don't blow up their engines, and to avoid costly warranty repairs.
cj7guy is offline
post #6 of 8 Old 10-11-2006, 10:37 AM
mike_dippert
mike_dippert's Avatar
the 4.0 has been around for a decade or so...the factory knows that thing inside and out, its at its peak in 2006, and to close to notice the difference in 97...why do you think the only engine mods not being bashed on this forum are strokers and forced induction. Computers, aftermarkets intakes, TB spacers, those stupid tornado things, and performance exhuasts...they all gain a fraction of what they claim on the 4.0, and to notice a difference you'd have to install all of them. unless you drive on the interstate above 2500RPM, then you might notice more of a difference.
if you change something like tires (a big jump, like 27 - 33+); regear; and for the thick skulled, the before mentioned engine mods...clearing the memory back to its "learning" mode might give improved performance...but reflashing to difference programming seems useless.
mike_dippert is offline
post #7 of 8 Old 10-11-2006, 11:12 AM Thread Starter
cj7guy
They put 3 cats on it by 06, clearly not for peak power/gas mileage.
I do that a good bit, but over 2500 far more often when accelerating around town. Why would the power only help on the highway??
I know the purpose of regearing, it doesn't make the engine any more powerful.
How do you know? Have you ever reprogrammed an engine computer? Turbo cars often gain 30hp or so from just an ECU reflash, I know that's not reasonable on a 4.0, but let's be honest, the 4.0 was tuned for reliability and consistency, not performance.
There's always room for improvement on a factory tune. I guess Jeep guys prefer bolt-ons though, as they are pretty darn popular, and aftermarket tuning is not popular.
cj7guy is offline
post #8 of 8 Old 10-11-2006, 09:25 PM
dougolupski
It's Heep not Jeep
Turbo cars are also modifying engine timing off of multiple sensors which largely base them selves on MAF sensor. The 4.0 motor ecu has no way of knowing accurately how much air is getting into the system. The Map sensor gives a base line number to the ecu to adjust timing and fuel but know where near the extent of a MAF. In essence what you are changing with those programing kits is the timing ratio compared to the MAF sensor. Which in most cases the timing is advanced to it's max point then is modified as you are driving by the IAC,MAF, and TPS sensors. You do get incredible increases in vehicles that have a MAF sensors but not in the 4.0. So you could adjust your timing and fuel mix if you knew someone to do it with a computer and the DC ecu program but for a stock motor all you are going to do is increase timing which will more than likely increase cylinder temp which will cause knock on low octane which will make you spend more money on gas.
That's why the only people you see mess with the ECU are the people who run forced induction. It's only because they have to.
Edit: The cat point is mute. It's a federal regulation for it to pass smog. They wouldn't add them if they didn't need to. The correct way to to talk about engine programing is they are set up to maintain the proper stochiometeric air/fuel ratio of 14.7 to 1 to minimize emmissions.
PCM reflash Reelm n Rubi TJ Wrangler Technical Forum 11 09-05-2013 09:10 AM
Auto reflash? onlyn8v TJ Wrangler Technical Forum 1 04-02-2008 11:57 AM
Idle problem after reflash PCM jgp TJ Wrangler Technical Forum 5 12-12-2007 12:42 PM
