Quantcast EBC yellow stuff brake pads/ centric prem rotors - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > EBC yellow stuff brake pads/ centric prem rotors
Old 06-05-2009, 11:31 AM   #91
JoWest45
I just got everything from Summit. I didnt get Centric rotors though, got all EBC pads and rotors front + rear. Seem fine to me. Really helped the 37s.
JoWest45 is offline   Reply With Quote
Old 06-08-2009, 01:12 PM   #92
jthompsn
Well its been almost a year now that I've been running this combo and made the original post and my brakes still feel great. I almost want to see how they handle 35's (need new tires soon)!!!!
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift...
jthompsn is offline   Reply With Quote
Old 07-21-2009, 04:44 PM   #93
RubiOR
Time for brakes
(On a side-note, what should one normally expect from the factory brakes on an '06 LJ Rubicon?)
So my brakes are starting to squeak a little which means it's time for an upgrade. I've read the threads and in my rig's current configuration I've decided to go with the Centric/EBC combo.
I did a quick Google for part numbers & prices and came up with the list below. I assume that the price for pads is for both sides, if I'm wrong please correct me. Is there ever a case where you would change pads on just one corner?
Finally, I haven't decided yet if I will tackle this myself or defer to a professional. I've never done brakes before... If anybody out there can suggest roughly what an install would cost that would be great.
Rotors at AutoPartsWarehouse
Front - $58.28 each
Part Number: CE120.67045
Manufacturer Number: 120.67045
Rear - $50.11 each
Part Number: CE120.67063
Manufacturer Number: 120.67063
Rotor Subtotal: $216.78
Pads at AutoPartsWarehouse
Front - $137.65 (Yellow) (assuming this is for both sides)
Part Number: E35DP41255R
Manufacturer Number: DP41255R
Rear - $62.96 (Green) (assuming this is for both sides)
Part Number: E35DP61673
Manufacturer Number: DP61673
Pad Subtotal: $200.61
Parts Total: $417.39
Final cost TBD based on tax, shipping and possibly installation.
Alternatively, finances may force a muti-stage upgrade. Particularly if I'm wrong about the "both sides or each" question on the pads.
Front Subtotal: $254.21
Rear Subtotal: $163.18
'06 Solar Yellow Rubicon Unlimited -- The Big Yellow Brick
Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy
RubiOR is offline   Reply With Quote
Old 07-21-2009, 04:58 PM   #94
robncar
Front - $58.28 each
Rear - $50.11 each
Those pads you listed come in pairs, you'll get one for each side, left and right.
DON'T FEAR THE RE-GEAR!!!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Old 07-21-2009, 05:07 PM   #95
RubiOR
Ouch... So the new numbers go this way:
Front Pads - $137.65 (Yellow) (per wheel)
Rear Pads - $62.96 (Green) (per wheel)
Pad Subtotal: $401.22
Parts Total: $618.00
Or
Front Subtotal: $391.86
Rear Subtotal: $226.14
Old 07-21-2009, 05:13 PM   #96
robncar
Or
Oh gosh no, that's not what I meant.
Those original part numbers you listed are for a pair, both left and right pads. So, you would order quantity one for the front of the Yellows and quantity one for the rear of the Greens.
______
|_____|
(O|||||||O)
|______|
[]===o==[]
Old 07-21-2009, 06:59 PM   #97
mrblaine
Brake Wizard
mrblaine's Avatar
Wouldn't it be easier to say that pads generally come packaged per axle?
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 07-21-2009, 07:01 PM   #98
RubiOR
Heh... I know the calendar says "Tuesday" but this has been more like a Monday!
So my original costs were accurate at $417.39 total or $254.21 front and $163.18 rear.
Old 07-21-2009, 07:03 PM   #99
RubiOR
Aye. I remember a physics professor (a long, long time ago) who always harped on the importance of specifying your unit of measure. "I don't care if it's furlongs-per-fortnight, just specify what you're using!"
Edit: That was directed at AutoPartsWarehouse who failed to put the unit of measure on the product, *not* at robncar!
Rob / Blaine, thanks for your advice!
Old 07-21-2009, 07:27 PM   #100
PDoyle
No matter... This is a good combo for ft brakes. The difference from the oem pads and rotors is amazing!
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar.
SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage.
PDoyle is offline   Reply With Quote
Old 08-01-2009, 03:27 AM   #101
storman113
Doing a search for the yellow pads. Added search for my Explorer also. Found RED pads for it. If the yellow is better than the green, is the red better than the yellow?
storman113 is offline   Reply With Quote
Old 08-01-2009, 06:02 PM   #102
CB3
No, the Red it not better, except for high speed road racing. The Red have the best hot stopping abilities, but their cold stopping abilities suck. They were made for racing, not DD use.
The Yellow were made for DD use and road racing. They do it all because they have good hot and good cold stopping abilities. On a DD, cold stopping ability is just as important as hot stopping ability. So the Yellow are the better DD choice. Red would be inappropriate for DD use.
Read what EBC says about both types of pads. They clearly explain all this.
CB3 is offline   Reply With Quote
Old 09-14-2009, 09:35 PM   #103
SHAKEnBLAKE
SHAKEnBLAKE's Avatar
It looks like thepartsbin.com and carpartwholesale.com have IDENTICAL prices, and currently there is a 10% discount code TPBcart or CPWcart (I found codes at retailmenot.com) bringing 98 TJ front EBC yellows and Centric premiums to $204.06 shipped. Just thought I'd share. Perhaps one of the two places is faster to ship, or has better customer service.
Shake & Bake with SHAKEnBLAKE - "Build Thread"
www.ohio4x4.com
98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
SHAKEnBLAKE is offline   Reply With Quote
Old 09-15-2009, 06:36 AM   #104
PDoyle
I bought mine from parts bin. They never shipped. They said they had them, but efter a few calls to them...they didn't. I won't use them again.
Old 09-15-2009, 09:56 AM   #105
SHAKEnBLAKE
^^ There is a difference between "partsbin" and "thepartsbin." Just wondering which you used.
www.ohio4x4.com
Glock Forum
