EBC yellow stuff brake pads/ centric prem rotors
#46 | |
Just an update for you all... Everything working great since the install, braking again feels much improved and smoother than stock. There is a slight increase in the amount of brake dust but I'd much rather be able to stop than worry about dust. I still get a little squeak once and a while from the rear drums. I'm about 1,200 miles into this set up and my only regret is that I didn't have the $$$ to get a Vanco kit!
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift... |
#47 | |
Did you consider doing your rear brake pads with green 7000's to help?
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar. SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage. |
#48 |
I would take it to mean that although a significant improvement, particularly for the money, it's still not a Vanco kit. The Vanco Kit is, as Jerry put it, the "Holy Grail" of Jeep braking. Also significantly more money.
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7 |
#49 |
Brake Wizard
The Holy Grail would be the 16" kit and one of Van's hydroboost kits. That would rule all others.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#50 |
Thanks, I've been searching for replacement brakes for a few days and found much info and pricing on EBC brakes, but how much more are the Vanco front brakes?
#51 | |
Brake Wizard
323-563-1588 and talk to Van.
#52 |
calling him now..
#53 |
wow!
After reading all the reviews on the EBC yellow pads and centric rotors I decided to pull the trigger and order that combo (autoparts.com 193.07 shipped). I had been running performance friction pads and thought they stop my 35" tires pretty well. OH BOY was I wrong, this new set up is AMAZING! After the install I went to go "break them in" and after my 4Th or
5Th pass from 30 mph to 0 I was locking up my 35" tires and stopping in half the distance as my old pads. I can now lock up the front tires at any speed if I want to. I think this pads should be mandatory for anyone running 35" or taller tires they are night and day difference from my old pads.
1997 TJ SE, 175,000 5 speed. 8k on new engine. RE 4.5" long arm.1" PA BL, tera 4:1. 35"x12.5"x15" MTZ, fab tech front bumper, warn rear w/carrier. Currie rock sliders, D44 in rear w/ arb. 488 gears. TBT sports cage. currie tie rod. |
#54 | |
Brake Wizard
#55 |
No problem, there is no comparison.
Is there a embedding procedure with the ebc pads? I know when I first installed the PF pads they had instructions on how to properly "embed" the pads to the rotors with a series of 30mph to 0 stops. The ebc pads gave know such instructions so after my 5Th pass and my tires where locking up I called it good.
#56 |
hey, I ended up doing this upgrade a month ago and I agree, they are flipping awesome. I'll back you up on these too. This is an upgrade that's well worth doing.
#57 | |
http://www.ebcbrakes.com/troubleshooting.html
'97 TJ Sport, 4.0L, AX-15, D30/35, Dayton Timberline AT 31x10.5x15s, Warrior rack, Silverstars, KC HiLites Replacement Fogs, Optima Yellow Top, EBC Greenstuff pads and Centric rotors, 164K '97 Rodeo, '96 Jetta, '02 Cabrio, '03 E46 |
#58 | |
i tried that site, comes up with alot of other sites
05 Unlimited, RE 4.5, 4.5 springs, adjustable front and rear track bar, 33x12.5 MT Baja Claw Radial, 15x8 MT Classic Locks, 4.88's, Tom Woods rear cv and sye kit superwinch, RRC front bumper, rear bumper with tire carrier, rocker guards, home made 1.5 seat risers |
#59 | ||
i am looking to get 33s soon. would this be an upgrade you would recommend? i have a 94 cherokee but i dont think that it matters. i can get the front for like 210.. what would you recommend for the rear?
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD Quote:
#60 |
Hey Quick question When you purchase these brake pads. They say set, is that meaning that the rear set is all 4 pads or just a rear wheel set? Sort of a stupid question but I dont want to blow 250 bucks and have to hassle returning them.
EBC Brake Pad Set E35DP61673 Green EBC Brake Pad Set E35DP41255R Yellow I cant seem to find the rear rotors, the part number listed is for a liberty... this iswhat i got from above, Rear Centric Premium Rotors 12067063
2004 LJ 1" JKS BL, 1" BMML, Rough country 3.25" lift with 2"puck up front 4.88 GEARS, D30 W/ AUSSIE LOCKER D44 33X1250X15 Currie Anti rock, Trail gear bumpers, Rokmen tummy tuck with Eng skid, Genright Rockers Smitty Bult XRC 10k winch
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
