EBC yellow stuff brake pads/ centric prem rotors
#31 | ||
Run your fingertip over them. My fronts with 42k are very worn down, deep ridge near the edge. I would not consider putting new pads against them.
#32 | |
Brake Wizard
Which one matters the most to you?
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#33 |
I haver had my yellows with centrics for about 3 weeks now and they are still awesome. Even better actually since the squealing has almost gone completely.
Yellows are not available for the rear, just green.
2005 Red Rubi Unlimited Auto WARN M8000, 3/8 Synthetic line, Kilby, Jeeperman, Jeepmedic, RE SF 4.5- all adj arms, RS9000x, TW shaft, 37" MTr's, RockCrusher, Currie, Rockhard, Alloy USA. Jeep Pics |
#34 | |
X2!!!!!!!!!!
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift... |
#35 |
I have been looking at doing the front brakes on my 01 XJ and came across this forum. Does EBC make Yellow stuff Pads for an XJ? Also can I get a set of Centric Premium rotors? One more question, where can I find the testing that mrblaine has done. I have been doing some searching and for some reason I can’t find anything.
Thanks
98 TJ Sport, 4.0, 5 speed, 2T Teraflex coil lift, 32 BFG M/T KM2 01 XJ Cherokee 4.0, RE 4.5 superflex, 31 BFG A/T |
#36 | |
olli '03 Rubi Just cuz you got the power, that don't mean you got the right! |
#37 |
my front rotors are warped and toasted, have been for a few years now.... so i just ordered some centric rotors...and getting Yellow pads for the front and green 7000s for the rear after funds are available...I hope they are as good as claimed!
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#38 |
So... where are ya'll finding the centrics and pads? Google isn't my friend tonight. :-(
'06 Solar Yellow Rubicon Unlimited -- The Big Yellow Brick Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy |
#40 |
www.car-stuff.com is where i got my set.
#41 |
http://www.buybrakes.com/ebc/pad-apps-Jeep.html
Note this statement in the above link: DO NOT FIT UPGRADE BRAKE PADS TO REAR OF VEHICLE UNLESS SAME UPGRADE FITTED TO FRONT Is that a mistake? |
#42 | |
Brake Wizard
#43 | |
DO NOT FIT UPGRADE BRAKE PADS TO REAR OF VEHICLE UNLESS SAME UPGRADE FITTED TO FRONT Did they mean to say " an equal or better" instead of "same?" |
#44 |
I've been reading the brake pad and rotor threads since getting my Jeep in '04, knowing this would be a DIY for me eventually. I never thought I would need anything more than the factory setup or equivalent, though, until Labor Day Weekend. I had three teens in the Jeep with me as we climbed to the parking lot at Brasstown Bald in GA. I pulled off at what I realized shortly after was the last gravel stop at the side of the road, maybe 100 yds from the top, to let 3 motorcycles shoot by (they waved appreciatively!). Now, however, I was on a steep grade on gravel. I thought I would just spin the 31s there, so I eased back onto the pavement where it took a great deal of pedal pressure and probably only 1 1/2 but seemed like 10 harrowing seconds to get the Jeep stopped. A little smoking of the clutch got us headed back uphill. I think it'll be the Yellow Stuff and Centric rotors at the next swap out. Trouble is, I have a ton of material left on the current pads. I've had the Jeep for nearly 40K and it looks like there's been no pad wear. It takes nothing to stop the Jeep in FL!
'97 TJ Sport, 4.0L, AX-15, D30/35, Dayton Timberline AT 31x10.5x15s, Warrior rack, Silverstars, KC HiLites Replacement Fogs, Optima Yellow Top, EBC Greenstuff pads and Centric rotors, 164K '97 Rodeo, '96 Jetta, '02 Cabrio, '03 E46 |
#45 | |
Brake Wizard
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
