Quantcast EBC yellow stuff brake pads/ centric prem rotors - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > EBC yellow stuff brake pads/ centric prem rotors
Old 08-29-2008, 11:21 PM   #16
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Originally Posted by jthompsn View Post
The EBC yellowstuff pads are part #EBCDP41255R, double check to be sure.
Centric Premium rotors #12067045.
Search around, you can find all sorts of different prices I've seen the pads go as high as $139.
Do you have to replace the rotors? Can I just put the yellow pads on the stock rotors? I've got about 60,000 miles on the original rotors. It's probably getting time to replace them anyway.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Old 08-29-2008, 11:33 PM   #17
mrblaine
Brake Wizard
mrblaine's Avatar
You can, but it's sorta like sneaking in and watching your granny take a shower. Just because you can, doesn't mean you should.
Do you really want to risk a 100 dollar plus set of pads on potentially crappy rotors?
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 08-30-2008, 12:05 AM   #18
mrblaine
Brake Wizard
mrblaine's Avatar
Originally Posted by thedirt View Post
Perhaps you've mentioned this in another post somewhere on here, but what stock-replacement rotor would you recommend when paired with the Yellows?
I vaguely recall that the OEMs weren't the highest quality.. but I'm curious to hear your thoughts.
We've had continual great success with the Centric Premium stuff in any application we've used it in.
I don't have a lot of time testing other brands, but there were a few that were tested based on cost and they just don't compare either in performance or longevity.
I am Savvy
Old 08-30-2008, 01:39 AM   #19
Flatbroke
Man that was funny.
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline   Reply With Quote
Old 08-30-2008, 01:45 AM   #20
Flatbroke
Originally Posted by Jerry Bransford View Post
Because of the testing by mrblaine as mentioned above, his results show the Yellow is, by far, the best braking pad he's found for the TJ. I can't wait for my ceramic pads to wear out so I can justify installing EBC's Yellow pads.
are you using ceramics on the rear or front Jerry?
Yellow 02 Sport
Haha
Russo
Old 08-30-2008, 06:52 AM   #21
Jeepguy1977
Not to hijack, but curious, if the front tires are off the ground and you spin them, how much drag should there be on them? Seems like I actually have to put a little effort into making my front tires turn even without the e-brake on and everything in neutral. ( this is with the vehicle off the ground)
Asking so that I know if I absolutely need to look at my brakes next or not
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote
Old 08-30-2008, 09:05 AM   #22
Pillswoj
Remember your turning everything back through the differential and driveshaft.
Friends don't let Friends run Bosch
My Wifes Cake Site - Check the Jeep Under Carved & 3D
Pillswoj is offline   Reply With Quote
Old 08-30-2008, 09:09 AM   #23
Pionex311
Well, after reading everything on this thread and reading up some of mrblaine's threads on brakes, I went ahead and bought a set of EBC Yellow Stuff pads and Centric Premium rotors. $228 including shipping to WA. I hope I'll be just as thrilled about this setup as you guys are. Quick question though, should I just buy autozone drums and shoes for the rear since it appears that they don't do much at all?
Pionex311 is offline   Reply With Quote
Old 08-30-2008, 10:17 AM   #24
jthompsn
You could go centric on the rear drums, I looked for any way to squeeze more stopping power out of the drums and shoes. Never heard anything about them, but the local parts store carried their drums/shoes so I picked them up. I would imagine they are better than OEM even if just by a small margin.
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift...
jthompsn is offline   Reply With Quote
Old 08-30-2008, 11:39 AM   #25
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Avatar
I've just started to search for the best price on these items, right now Summit Racing has a pair of pads for $129. Don't know about the rotors yet.
Now for the stupid question because I know nothing about brakes. I have 4 wheel disc brakes on my LJ. Am I correct in guessing that the front and rear pads and rotors are the same given that I have a D30 axle in the front and a D44 in the rear?
Edit: The rotors are different
Front Centric Premium Rotors 12067045
Rear Centric Premium Rotors 12067063
Edt #2: The Pads are different too. EBC Yellow Stuff brake pads aren't available for rear brakes.
Front EBC Yellowstuff Pads E35DP41255R
Rear EBC Greenstuff Pads E35DP61673
The best prices I've found are at thepartsbin.com.
Thanks,
Drew
There's a great lower division class called "Writing for Effective Communications so you don't go through the rest of your life confusing everyone who reads what you write 101" at Washington State University. I highly recommend it.
Ichabod1960 is offline   Reply With Quote
Old 08-30-2008, 12:21 PM   #26
Benderff
intentionally left blank
Benderff's Avatar
After reading on here I just ordered EBC Yellow's and the Centric rotors from the parts bin. Overall they were cheaper then the free shipping sites, and they have a discount code you can use for $20 off. I did a quick search and found it.
Enter
TPB02
Is it worth throwing green stuff's on the rear?
Benderff is offline   Reply With Quote
Old 08-30-2008, 02:56 PM   #27
RandyTJ
I have an 05 Rubi - disc front and rear............
Can someone give me the part# for the front and rear for the yellows and also for the greens.....
I only have 20,000 miles on my factory rotors.....I'll probably stick with them as long as it's OK.
White 2005 LJ, Rubicon, Rubicon Express 3.5 SuperFlex, Pro Comp 315/75/16 Xtreme AT's, Pro Comp 97 16x8 wheels, UCF Tummy Tuck, 1" Prothane BL, 1" JKS MML,Tereflex Disco's, 10,000 lb. winch. CB Radio, Fire Extinguister, Synthetic Fluids, Driving Lights....
RandyTJ is offline   Reply With Quote
Old 08-30-2008, 03:04 PM   #28
mrblaine
Brake Wizard
mrblaine's Avatar
With your rig, you'd be better off getting better brakes and putting the money you'd spend on the pads towards them.
I am Savvy
Old 08-30-2008, 03:18 PM   #29
Jeepguy1977
Oh I know.just didn't seem like it should be harder to turn than the rear with the limited slip in it.
Old 08-30-2008, 06:05 PM   #30
Zeep
Zeep's Avatar
Its probaly to soon to ask this, but how are they for dusting up the wheels?
Zeep is offline   Reply With Quote
Glock Forum
