EBC Pads on a stock brake set-up
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#91 | |
http://www.autoanything.com/brakes/61A3070A-1A1.aspx
At the bottom of the page above, it shows some generic review of the Green pads. It got some good reviews.
DailyDrivenTJ.com JUST For Jeep TJ Owners Around the World! |
#92 |
Hmmm same page diff pads: http://www.autoanything.com/brakes/61A3072A0A0.aspx?kc=0&from_search=1
The original point and click interface was a Smith & Wesson. |
#93 |
Do it right or not at all
![]() Join Date: Jan 2003
Blaine said that was normal but that it would go away at some point... I think he said 200-300 miles or so.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#94 | |
98 XJ, Pearl Green, 4.5" lift, 32's Daily Driven. BEAT IT! BREAK IT! FIX IT! |
#95 | |
Brake Wizard
But, if you start with something that big, tuning up the rest of the system will only make it better.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#96 |
Awesome, it seriously sounds like a School Bus is coming to a stop, I put some Disc Break Quiet in there and it helped out a bit but still squeaks on a hard stop.
[B][U]2001 Wrangler TJ Sport 5-Speed[/U][/B] Dana 44 Rear, 3.73 Gears, 4" ProComp Lift w/ Daystar 1 3/4" Spacer in front, Skyjacker Hydro 7000 Shocks, JKS Quicker Disconnects, 33"x12.50" Pro Comp Xtreme M/T, R.C. Adj. Front Track Bar, RR 1/4" CA Mounts, Front Aussie Locker, Front/Rear Riddlers, EBC Yellowstuff brake pads, Rokmen Power Steering Skid, Rusty's Radiator Skid, Rokmen Mercenary Front Bumper, Rokmen Mercenary Rocker Guards, Warn Engine/Oil Pan Skid, Tuff Designs Rear Tire Carrier/Bumper, Warn M8000 Winch, IPF H4 Headlight conversion w/ IPF Fatboy X55 bulbs [U]Waiting to be installed:[/U] *Rusty's Steering Box Support Brace |
#97 | |
My brakes aren't as bad as you described so maybe I don't have quite the issue other LJ's are having. Even with 37's on steel my brakes aren't nearly as bad as my old Suburban with PFC's, which got much worse here in Illinois with the cold. You know a brake system is bad when one of the TSB's actually had the techs install a thicker brake pedal cover...no joke, mine had the upgrade to make it "feel" higher. Good luck onthe LJ brakes as I plan on ordering a setup as soon as it's perfected. In the mean time the Yellow's are going on as a band aid. Thanks again for all the info.
#98 |
Rear Drum Brake Shoes
Hi Guys,
Very interesting reading in this thread. It is about time to replace my rear brake shoes, and I was wondering if anyone could recommend a brand of brake shoes that were any better than the stock ones, or should I just put the stock ones in? (1997 TJ Dana 44 Drum Brakes) Any Suggestions ![]()
1997 TJ Soft Top/ Half Doors 4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header 31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights |
#99 | |
#100 | |
Brake Wizard
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
