EBC Pads on a stock brake set-up
| Ruffstuff Axle Simple Swap Kit! | Truck-Lite's New LED Headlamp Series | Spartan Lockers FREE SHIPPING Excellent Prices |
#76 | |
You are like one of those bad wives that gets mad at everything, no matter how inconsequential it is.
Guns don't kill people. People with mustaches kill people. |
#77 | |
Brake Wizard
I only get mad at the things that make me mad.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#78 |
Hahahahahahahahaha!
I'm thinkin' new sig material. Or at least an addition to mine.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion." |
#79 |
I think I dare to add to this thread (flame retardant suit is on)...
I just installed new EBC 7000 Green pads on my 01 TJ last night, I turned the rotors as well. I had a lot of fun at 1am doing the hard stops to brake in the brakes. Everything seemed to go great, except that today I am getting a squeeling from my brakes with moderate brake pedal pressure. If I jam on the brakes no squeeling/squeeking. Yes, I put brake lube all the places I was supposed to. I read in another threat that I should sand paper down the rotors and pads? But this doesnt make sense to me. I just did this last night, so is there some break in time to stop making noise or did I screw something up? ![]() ps. braking is AMAZING now. Locking up the tires is easy, plenty of stopping on 33's with this setup. I can't imagine what a Vanco setup can do. [flame suit on]
2012 Sport in Dozer |
#80 |
Out of curiosity, is the break-in any different than any other pads?
I can't help but wonder if there isn't some amount of compatability between rotor material and pad material. I also can't believe that someone threatened you to use sandpaper on the rotors. Seems you would have to do it constantly. Unless, maybe the rotors got glazed?
My jeep makes a ticking noise too It has done it since it was new I couldn't care less- I must confess I use FRAM filters too! |
#81 | |
Brake Wizard
Who told you to do hard stops to break them in?
#82 |
My Yellows should be arriving today, I'm going to put them on when I do my Aussie locker install since I have to remove the calipers anyways.
Just so I know in advance, what is the proper break-in technique to assure proper pad seating?? Last time I looked the rotors looked properly worn, do I need to do anything to them? Or should I be able to the just throw the pads on?
[B][U]2001 Wrangler TJ Sport 5-Speed[/U][/B] Dana 44 Rear, 3.73 Gears, 4" ProComp Lift w/ Daystar 1 3/4" Spacer in front, Skyjacker Hydro 7000 Shocks, JKS Quicker Disconnects, 33"x12.50" Pro Comp Xtreme M/T, R.C. Adj. Front Track Bar, RR 1/4" CA Mounts, Front Aussie Locker, Front/Rear Riddlers, EBC Yellowstuff brake pads, Rokmen Power Steering Skid, Rusty's Radiator Skid, Rokmen Mercenary Front Bumper, Rokmen Mercenary Rocker Guards, Warn Engine/Oil Pan Skid, Tuff Designs Rear Tire Carrier/Bumper, Warn M8000 Winch, IPF H4 Headlight conversion w/ IPF Fatboy X55 bulbs [U]Waiting to be installed:[/U] *Rusty's Steering Box Support Brace |
#83 |
Personally -I lean towards... new pads, new rotors. Unless you can't afford it.
#84 | |
The only reason I think new rotors would be needed is if they were worn below or near the replacement spec, or even severly warped. In most cases you can just throw pads on a properly worn rotor, I've done it several times on several vehicles without consequences. However, these are a Kevlar pad (the Yellow ones) and I was asking because people have mentioned sandpaper and turning them prior to install.
#85 |
(Really) really in the most prefect sense. really really really. Preeeeeflectively.
Just my own policy.- just like FRAM filters. ![]()
#86 |
I saw the break in procedure on Stu's website, 10 stops from about 45 mph (without full stop), cool, repeat. They were quiet at first, so maybe now I'm in the second 4-500 mile period where they "wear" in or whatever they do, I don't know the right terminology.
The sandpaper idea was on here, I used the SEARCH function before I asked the question, but didn't like what I found... http://www.jeepforum.com/forum/f9/squeeky-brakes-284784/?highlight=brakes+sandpaper Anyway, braking is great now.
#87 |
Do it right or not at all
![]() Join Date: Jan 2003
To my way of thinking, new rotors are only needed if the old rotors are worn past the point they can't be turned smooth and stay within specs. Throwing out a set of rotors just because you're installing new pads makes zero sense to me. Why more than double the cost of a brake job just because you can if it's not needed:
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#88 |
Well, when I get my green pads, rest assured I'll be putting new rotors on also. That'll be about one year on the current setup ~16000 km. I'm going to wait for a hint on the (top) most recommended brand rotor at the time.
Hi Jerry!
#89 | ||
http://www.ebcbrakes.com/assets/typicalq%26a.html Quote:
2005 Red Rubi Unlimited Auto WARN M8000, 3/8 Synthetic line, Kilby, Jeeperman, Jeepmedic, RE SF 4.5- all adj arms, RS9000x, TW shaft, 37" MTr's, RockCrusher, Currie, Rockhard, Alloy USA. Jeep Pics |
#90 |
Ok, so I installed my EBC Yellowstuff pads yesterday when I was putting everything back together after my Aussie install, which went very smoothly. The pads are awesome, I could easily lock up my 33's without too much effort, the only problem I'm having so far is they started making one hell of a screaching sound after the break in material wore off, but I'll check that out today. The breaking is night-and-day!
But I just wanted to let everyone know, over all, these pads are awesome, and a great upgrade for those who aren't quite ready to upgrade the whole set-up yet. It's a very well spent $115, the breaking is much more consistant, when I put my foot on the pedal it doesn't require added pressure as you come closer to a stop, the pads just do the work for you, as they get hotter they actually break more ubruptly. These get my "highly recommended" stamp!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
