Eaton E locker wiring help? - JeepForum.com
post #1 of 7 Old 06-28-2010, 06:11 PM Thread Starter
champelite210
I bought a used E locker for my 8.8. and can't figure out the push button switch wiring. It has 3 prongs. one for ground, one for 12 volt ignition and one for 12 volt battery. Anyone have a pic or care to go look at there switch and let me know. There is nothing in the instructions that says what goes where on the switch.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #2 of 7 Old 06-28-2010, 06:17 PM
wushaw
Rockin jeep
wushaw's Avatar
wushaw is offline
post #3 of 7 Old 06-28-2010, 07:03 PM Thread Starter
champelite210
I checked that out but it's still hard to tell which pin is which. I'd really like to see a diagram or picture of the back of the switch.
post #4 of 7 Old 06-28-2010, 08:22 PM
wushaw
Rockin jeep
wushaw's Avatar
That is a diagram of the circuit as to how it should be wired. Is there 1A, 2A & 4B on the back/side of the switch? If so plug in according to the diagram.
wushaw is offline
post #5 of 7 Old 06-29-2010, 06:13 AM Thread Starter
champelite210
Thanks. I'll check my switch out when i get home.
post #6 of 7 Old 06-29-2010, 07:24 AM
NotURMailman
NotURMailman's Avatar
You shouldn't have non-switched battery power going to the switch. You should have ignition switched power in (1A), power out to the locker relay(2A), and a ground (4B-for the LED in the switch).
The relay should have switch power in, fused battery power in, a ground, and power out to the locker.
Assuming you are using a standard Bosch style automotive relay the relay connections would be:
30 - fused battery power
85 or 86 - power from the switch terminal 2A
86 or 85 - ground
87 - power out to locker harness black wire with red stripe
87a - not used
The black wire from the locker harness just needs to be grounded.
Be sure to use the harness and connectors that came with the locker, because it looks like there is a diode already built in to it (probably in the vehicle side of the harness inside of the plug).
Hope that helps...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #7 of 7 Old 06-29-2010, 07:31 AM Thread Starter
champelite210
Thanks.
eaton e locker , wiring
eaton e-E-Locker dtriplej6 YJ Wrangler Technical Forum 5 10-25-2007 07:28 AM
Eaton E-locker M&C_TJ TJ Wrangler Technical Forum 1 01-14-2007 10:19 AM
Eaton e locker Glass TJ Wrangler Technical Forum 2 08-07-2005 03:11 AM
Eaton E Locker jeepnut00 YJ Wrangler Technical Forum 0 06-18-2005 09:43 AM
Eaton E-Locker tomkirkland4 TJ Wrangler Technical Forum 8 03-04-2005 06:09 PM
