an easy question - JeepForum.com
post #1 of 2 Old 04-02-2008, 08:43 AM Thread Starter
TEEJAY
an easy question
i have heard alot of talk about a broken clockspring affecting cruise control, air bags, and horn at the same time.........but what if the horn is the only component not working? is it possible that the clockspring is still responsible?
TEEJAY is offline
post #2 of 2 Old 04-02-2008, 01:11 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Definitely. Everything electrical on the steering wheel has to go thru the clockspring, so it's worth checking. If you've already checked the rest of the circuit like the fuse/relay, it could also be the switch... but that's part of the airbag cover so it's even more expensive than the clockspring.
I'll be Savvy someday!
neZZr is offline
Easy Question DKremers Wrangler General Discussion 7 01-14-2010 03:41 PM
question from newbie, go easy on me TJindaboro TJ Wrangler Technical Forum 9 05-03-2009 07:48 PM
5.3 to nv3550 easy question troubleshootn YJ Wrangler Technical Forum 4 03-26-2009 03:10 PM
Need help easy Question! nofunnynickname TJ Wrangler Technical Forum 1 11-06-2007 01:04 PM
Easy Fit Question Flyusaf2002 TJ Wrangler Technical Forum 5 01-14-2006 06:05 AM
