Easy Fit Question - JeepForum.com
post #1 of 6 Old 01-13-2006, 05:24 PM Thread Starter
Flyusaf2002
Easy Fit Question
Would a Steel Horse 2 piece hard top from a 2004 fit onto my 99 TJ? Also, i've got soft upper windows - would I need to change to hard doors? Thanks,
Andy
STEEL CITY JEEP CLUB MEMBER # 17
99 Green TJ "Gracie" SOLD
2001 Red WJ "Ginger"
Flyusaf2002 is offline
post #2 of 6 Old 01-13-2006, 05:30 PM
CWaldrop
CWaldrop's Avatar
03 to 06 factory hard tops don't have fents for air equilibrium as in previous models. To compensate the factory tailgate has vents. I'm not sure if this is true with the Steelhorse. Not sure about the soft uppers either.
CWaldrop is offline
post #3 of 6 Old 01-13-2006, 06:34 PM Thread Starter
Flyusaf2002
nobody else has any info?
Thanks,
ANdy
post #4 of 6 Old 01-13-2006, 07:11 PM
maddiver
DUDE!!! If you can avoid putting a Steel Horse two-piece on ANYTHING - AVOID IT!! I have one got a year ago. The design is poor, the fit worse. IF you're lucky enough to get it to fit just right the first time then you'll be VERY lucky.
I've used mine for a total of 3 months and will most likely give it away free. It sucks. The engineering for fit and attachment to the body is really bad.
I've actually had to drill holes in various places and manufacture various clamps to keep it on the Jeep!
Good luck - these things suck!
maddiver is offline
post #5 of 6 Old 01-13-2006, 07:12 PM Thread Starter
Flyusaf2002
That's very helpful, i really appreciate the info. Does anyone disagree?
Andy
post #6 of 6 Old 01-14-2006, 06:05 AM
JeepJohnson
Steel Horse is pretty much known for sucking.
JeepJohnson is offline
Easy Question DKremers Wrangler General Discussion 7 01-14-2010 03:41 PM
5.3 to nv3550 easy question troubleshootn YJ Wrangler Technical Forum 4 03-26-2009 03:10 PM
Some easy question(phone) riverboyTJSport Wrangler General Discussion 2 03-20-2009 07:33 PM
an easy question TEEJAY TJ Wrangler Technical Forum 1 04-02-2008 01:11 PM
Need help easy Question! nofunnynickname TJ Wrangler Technical Forum 1 11-06-2007 01:04 PM
