Easiest way to get teh PCV or CCV (watever its called) off to clean - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Easiest way to get teh PCV or CCV (watever its called) off to clean
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military DiscCurrie Currectlync Steering Upgrade Kits and Currie Anti-R
Unread 09-20-2009, 01:57 PM   #1
pfifer
Trying to get the PCV or CCV value off to clean, whats the easiest way to do this with out breaking it? Thanks!
1999 TJ Sport l 4.0L l Ford 8.8 l HP30 l 4.88s l Mickey Thompson 35s l F&R Tru Tracs l Magnoflow Exhuast l And Much Much More...
pfifer is offline   Reply With Quote
Unread 09-20-2009, 02:08 PM   #2
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
There rough and brittle and you will probably crack it... no doubt.Buying a new one is usually the easiest.
GOLENJEEPTJ is offline   Reply With Quote
