Quantcast Early 97 TJ MAP sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Early 97 TJ MAP sensor
Old 03-20-2010, 06:41 PM   #1
jeepwrangler97
Wheel Weber
jeepwrangler97's Avatar
Is the early 97 MAP sensor different from the rest, I was told by the dealer 96-04 4.0 was the same MAP (also some durangos, cherokees, grands, dakotas, full size van, some others..).
I got the part number the dealer said would work from a junk yard, it doesn't. The plug on my harness looks more like one that I saw on a 93 ZJ. I know that YJ's and pre 96 XJ's don't have MAP sensors, but the ZJ's do, is it possible that early 97's have the same MAP as ZJ's? I know a lot of sensors are different from early 97 to later 97, but I thought the MAP was going to be the same. The reason I don't have the MAP already is because I am doing a 2.5 to 4.6 swap. I'm going back to the JY tomorrow and I'm going to grab the ZJ sensor and see if if works, I'm also going to take the part of the harness that I got the MAP from today and see if the wires are the same color as the ones on my harness, so I figure I can either use a different MAP or change the harness end???
I really don't want to get one new, unless I have to because they are $11 at the JY and $100 at the dealer. Thanks for any input JF (are he high five Smilies new?)
Also my TJ was made in 4/96
My 2.5L to 4.6L Stroker Here
Originally Posted by CaptainSlow001 View Post
saw me laughing at her and proceeded to hit me in ma nose :rofl:
jeepwrangler97 is offline   Reply With Quote
Old 03-20-2010, 06:51 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Early TJs like I had too (my '97 was built 3/96) often used sensors from the YJ. I bought a TJ TPS (throttle position sensor) for a '97 TJ but its plug didn't fit. I swapped it for a '95 YJ's sensor and it plugged right in.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 03-20-2010, 06:57 PM   #3
jeepwrangler97
Wheel Weber
I bought a TPS and a IAC for a 97 too, I ended splicing a connector for a newer TPS into my harness that I got from a newer harness my dad had sitting around, so I'm glad to hear that the YJ TPS works, because when I get my Jeep running again, I'm hoping the TPS works, if not I'll put the old connector back on and get a YJ TPS. I think I'm going to try the ZJ sensor for the MAP tomorrow before I do anymore splicing.
Thanks Jerry, good luck with your TJ, hope you get it back soon.
EDIT: I thought about pm'ing you before making this thread because I know your TJ was made early also, so thanks again
Old 03-20-2010, 07:17 PM   #4
Rammer500
justjeepin.org
Rammer500's Avatar
From looking at the parts manual, there are two MAP sensors for the 97. Part# 56028303 is for the non-enhanced OBD2, which should be the early 97. It also states that the 4cyl. uses the same one.
Part# 56029405 which is for the enhanced OBD2. It also is used for both the 4 and 6 cylinders.
99 TJ 4.0 5 Speed Sport, 2.5" Rough Country Lift, 1.25 Body Lift, 1" MML, SYE and CV shaft,JKS Quicker Disconnects, 33x10.50 BFG Mud Terrains,4.56 gears, Super35 w/ Ected Locker, Warn 8274 and some other stuff.
99 TJ 4.0 Auto Sport, 2.5" Rough Country Lift, 1.25 body lift, 1" MML, 33x10.50 BFG Mud Terrains, JKS Quicker Disconnects, wife's Jeep
2011 JK Sport, Auto, Teraflex leveling Kit, 285/70-17 Kelly Safari TSR
Rammer500 is offline   Reply With Quote
Old 03-20-2010, 07:22 PM   #5
jeepwrangler97
Wheel Weber
Thanks for those numbers that helps a lot actually ( I guess I need to calm down with the , but they're cool)
Old 03-21-2010, 01:20 PM   #6
jeepwrangler97
Wheel Weber
Well the ZJ sensor didn't work, but I did find the wiring end for the sensor I got yesterday, it has the same color codes on the wires as my harness so hopefully it will work
Old 03-21-2010, 02:19 PM   #7
Rammer500
justjeepin.org
Rammer500's Avatar
How come your not using the one from your 2.5?
Old 03-21-2010, 02:31 PM   #8
jeepwrangler97
Wheel Weber
because I left it on the 2.5 when I sold it , I'm going to email the kid today and see if he still has it, he has a YJ, so he doesn't need it
Glock Forum
