E brake shoe adjustment question. - JeepForum.com
post #1 of 6 Old 02-18-2011, 10:54 PM Thread Starter
I have a ford 8.8 rear axle with disk brakes and e brake shoes. Theres some kind of adjustment screw at the bottom where the shoes meet. What is this called and how do I find out how long its supposed to be?
Old build 99 TJ 100wb on 35s and arbs.
New build D60s, 40s etc.
I void warranties.
Ezalycasaid is offline
post #2 of 6 Old 02-18-2011, 10:58 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Star wheel adjuster and it's supposed to be exactly 28.54mm long measured between the two flat spots that wrap around the ends of the shoes.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 6 Old 02-18-2011, 10:59 PM Thread Starter
Thank you. Really appreciate the info.
I void warranties.
post #4 of 6 Old 02-19-2011, 12:34 AM Thread Starter
Ezalycasaid
Thats was a very oddly specific question to have answered that fast. Do you change ebrake shoes often on a ford 8.8 or did u just fire that off from memory?
I void warranties.
post #5 of 6 Old 02-19-2011, 12:40 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's actually a made up answer pulled straight from my butt.
A teeniest bit of a search would have revealed that it is in fact a star adjuster and the dimension is predicated upon the wear of the friction lining combined with the internal dimensional drum diameter. Properly adjusted, the star wheel adjuster spreads the shoes far enough apart at the bottom to keep the friction material in close enough proximity to the drum surface that a moderate application of the parking brake lever will create enough frictional resistance to stop the vehicle from rolling on mild to moderate inclines.
I figured since you like to make threads that turn into FUBARfests of phenomenal proportions, I'd get you started off on the right foot.
You were supposed to ask how one gets an accurate measurement.
I am Savvy
mrblaine is offline
post #6 of 6 Old 02-19-2011, 02:53 AM
Ross00TJ
Mrblaine, I don't mean to piggyback but how does one get that exact measurement?
Future Electrical and Computer Engineer - University of Colorado - Boulder | Bringing Logic to JeepForum since 2010!
"Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Ross00TJ is offline
8.8 Parking Brake Shoe - Problem linusb YJ Wrangler Technical Forum 7 10-10-2010 01:30 PM
8.8 e brake adjustment champelite210 YJ Wrangler Technical Forum 9 03-22-2010 06:25 PM
E-brake needs adjustment 04limegreen TJ Wrangler Technical Forum 30 10-13-2009 10:07 AM
E-brake Adjustment idgit0488 TJ Wrangler Technical Forum 4 08-01-2006 07:05 PM
Brake Pads & Shoe recommendations? BNovak TJ Wrangler Technical Forum 2 07-27-2004 06:05 AM
