E-brake not holding..... - JeepForum.com
post #1 of 20 Old 07-19-2006, 10:20 PM Thread Starter
primus
I just noticed today that my e-brake doesnt completely hold anymore on my 01' sport. Anybody know any common problems with the e-brakes? I'm not to mechanically inclined but if something just needs tightening up I could probably do that. Any suggestions??
primus is offline
post #2 of 20 Old 07-19-2006, 10:28 PM
Rocky529
Rocky529's Avatar
Whatever you do, it is inside the drums. It is not recommended to mess with the e-brake linkage itself.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 20 Old 07-19-2006, 10:53 PM
JESSETHELJ
JESSETHELJ's Avatar
Jeeps have self adjusting drum breaks right? cause if they do there should be a hole in the front or back where they can be adjusted. could some one back me up here, and tell him how to.
2004 LJ*RIP Love * Ex-Wife Stole you and Sold you *Current 1999 XJ Heep
JESSETHELJ is offline
post #4 of 20 Old 07-19-2006, 10:57 PM
jcd
jcd's Avatar
I learned the hard way that TJ e-brakes are not the best when my three day old 97 backed itself down the driveway while warming up landing in a 48" drainage ditch. The brake was still fully applied when I went to get it out of the ditch, so it clearly was not adjusted properly.
The dealer was able to tighten the cable giving the lever about half the throw, but a total death grip. Of course I have no idea how to make said adjustment, but do know it can be done
2008 Jeep Sahara Unlimited
Terraflex 4" 35's 5.13
jcd is offline
post #5 of 20 Old 07-19-2006, 11:05 PM
Rocky5
Rocky5's Avatar
is there NOT a cable under your jeep that runs down the center of the jeep. On my LJ, the cable is very easy to identify...but mine is an 06 with rear discs too...I have NO idea about your 01, just an obervation..
2006 Solar YELLOW UNLIMITED-6-Speed
-Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines
-Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar.
Rocky5 is offline
post #6 of 20 Old 07-19-2006, 11:06 PM
TruckMuddr
Always Something
TruckMuddr's Avatar
DIAGNOSIS AND TESTING - PARKING BRAKE
NOTE: Parking brake adjustment is controlled by a cable tensioner. Once the tensioner is adjusted at the factory, it should not require further attention. However, there are two instances when adjustment will be required. The first is when a new tensioner, or cables have been installed. And the second, is when the tensioner and cables are disconnected for access to other brake components.
The parking brake switch is in circuit with the red warning lamp in the dash. The switch will cause the lamp to illuminate only when the parking brakes are applied. If the lamp remains on after parking brake release, the switch or wires are faulty, or cable tensioner adjustment is incorrect.
In most cases, the actual cause of an improperly functioning parking brake (too loose/too tight/won't hold), can be traced to a parking brake component.
The leading cause of improper parking brake operation, is excessive clearance between the parking brake shoes and the shoe braking surface. Excessive clearance is a result of lining and/or drum wear, drum surface machined oversize, or inoperative adjuster components.
Excessive parking brake lever travel (sometimes described as a loose lever or too loose condition), is the result of worn brake shoes, improper brake shoe adjustment, or improperly assembled brake parts.
A condition where the parking brakes do not hold, will most probably be due to a wheel brake component.
Items to look for when diagnosing a parking brake problem, are:
Rear brake shoe wear.
Drum surface machined oversize.
Front cable not secured to lever.
Rear cable not attached to lever.
Rear cable seized.
Brake shoes reversed.
Parking brake strut not seated in shoes.
Parking brake lever not seated.
Parking brake lever bind.
Adjuster screws seized.
Adjuster screws reversed.
Richard Harvey Jr.
'04 TJ, X, 4.0, Auto, Silver, D30/D44 w/LS & 4.56's, RC 4" Series II, PA 3" BL, Advanced Adapter's TC Bracket, 15x12 Eagle Alloys 058, 15/35-15 TSL, 4x K/C DayLighters & Windshield Mounts, Ventvisor's Bugsheild, Door Sill & Window Vents, Fabtech Front Bumper & homemade Rear W/ Backup Lights, Hurculiner.
"It's Always Something And It's Never Good" - TruckMuddr
TruckMuddr is offline
post #7 of 20 Old 07-19-2006, 11:07 PM
MoJeeper
2009 JK Wrangler
I totally rebuilt mine and they still suck. You are suppose to be able to adjust them by backing up several times and slamming on the brakes, never work for me. But there is a hole on the bottom of the backing plate that you can stick a screwdriver in and adjust by turing it..its hard to explain if you have never seen the inside of a drum brake. I'm gonna try adjusting the cable in the next couple of weeks and see if that works.
09 JKU Sahara
MoJeeper is offline
post #8 of 20 Old 07-19-2006, 11:13 PM
Rule303
I did the backing up and slamming on the brakes. Neighbors thought I was crazy.
Rule303 is offline
post #9 of 20 Old 07-19-2006, 11:37 PM
$lick
leave it in firstttttt shut it off
$lick is offline
post #10 of 20 Old 07-19-2006, 11:44 PM
TruckMuddr
Always Something
TruckMuddr's Avatar
If I leave mine in 1st, it won't let me remove the key
Richard Harvey Jr.
post #11 of 20 Old 07-19-2006, 11:49 PM
Red_
2016 KL Cherokee
You can tighten the e-brake cable but thats not the solution. The bracket is roughly under jeep where the front of the backseat would be. Should have 1 cable pointing to the front of the jeep, and two heading to the rear. The adjustment bolt is on the front cable somewhere.
Do the forward-back-slam-on-the-brakes bit and that will readjust the drums properly. To keep them in spec when ever you are backing up always hit the brakes hard rather then just coasting to a stop.
Depending how many miles you have your shoes could be warn. Mine did this around 38k and the auto adjustment fixed it pretty much
Red_ is offline
post #12 of 20 Old 07-19-2006, 11:52 PM
farinspace
mines are slipping also ... 4x4xplor just put up a great write-up: http://4x4xplor.com/drum-brakes.html
98 TJ, 4.0L I6, 5sp, 4.88 Alloy Gears, D30[Aussie Locker]/D44[Detroit TrueTrac]
33" Toyo Open Country MT, 2" BB Lift + 1" Eng./Body Lift, TW SYE + Drive Shaft
farinspace is offline
post #13 of 20 Old 07-20-2006, 12:02 AM
JESSETHELJ
JESSETHELJ's Avatar
I knew they could be adjusted. Depending on the amount of miles you have on those current set of brakes, time for replace, or adjust them. They can get mucky from mud and not adjust it if theres not alot of mile on those brakes.
post #14 of 20 Old 07-20-2006, 12:30 AM Thread Starter
primus
well i just tried slammin on the brakes like 10 times...and it definitely didnt work. All that did was wake up some of the neighbours...lol.
primus is offline
post #15 of 20 Old 07-20-2006, 12:32 AM
Red_
2016 KL Cherokee
So you went forward at speed, hit the brakes hard full stop, then backwards at speed hard full stop? Do it about 10-20 times, if you cant get em beyond that, probably time to open up the drum
Red_ is offline
How are your Moabs holding up? vtx531 TJ Wrangler Technical Forum 10 10-12-2009 10:20 PM
holding up the jeep will02sport TJ Wrangler Technical Forum 3 02-24-2008 08:55 AM
what is this holding my tire on? pic derfin TJ Wrangler Technical Forum 30 08-18-2007 10:38 PM
Holding flag nut...? thejafe TJ Wrangler Technical Forum 13 11-06-2005 07:36 AM
Holding down the hard top??? spark plug YJ Wrangler Technical Forum 11 01-29-2005 01:07 PM
