DW and Trac bar upgrade for stock TJ with no lift - JeepForum.com
post #1 of 5 Old 07-20-2010, 05:25 PM Thread Starter
johnlo23
My 2004 TJ is completely stock except for the tires. It just turned over 100k miles last month. I have Goodyear SilentArmor 31X10.5's on the stock rims. The tires have about 40k on them. I rotate them about once a year and there is no noticeable uneven tread wear.
Just last week I started getting a shimmy btwn 52 & 56 mph which I thought was DW, but probably doesn't fit the definition. It's a scary, violent shake at that speed, but it goes away if I speed up or slow down. It seems like a harmonic problem only in that specific speed range.
I am going to get the tires balanced this week and see what effect that has.
From what I've read, the next most often culprit is the trac bar. I checked the bolts and had to re-torque the trac bar axle side, but all other components on the front end were tight. My control arm bushings do have some small cracks on the visible edges, but as that seems like a bigger job, I'd like to try to rule out the trac bar first.
SO... if I choose to just replace the trac bar, I think I should choose an adjustable in case I decide to add a lift in the future. I also would like to go beefier than stock. I have read some older posts and can't determine if any of the aftermarket rods will work on my TJ with 0" of lift. I have the Dana 30 with the stock diff cover.
Has anyone upgraded the track bar on a stock TJ without the need for other changes?
johnlo23 is offline
post #2 of 5 Old 07-20-2010, 06:57 PM
MJBinNM
There have been several posts about adjustable track bars hitting the diff cover with less than 4 inches of lift.
The stock track bar for your stock set-up is plenty strong. It's usually the bushing at the axle that is the problem, but with 100k miles it's likely that other components are worn. It is kinda painfull to spend almost as much on a good OEM type bar as you would for a good adjustable one, but an adjustable one may just create more problems.
I just replaced mine with the MOOG track bar for around 100 bucks. It has a heavy duty bushing MOOG Track Bar Bushing. I replaced the whole thing since there was a little play in the TRE Joint at the frame. (It can be found online cheaper, but Advance Auto Parts had the best images I could find with a quick search)
MJBinNM is offline
post #3 of 5 Old 07-20-2010, 07:27 PM
hustler905
I have done lots of research on this, just get a stock one. I have 0" lift as well, and there isn't an aftermarket bar that you will see the benefits of.
hustler905 is offline
post #4 of 5 Old 07-22-2010, 01:58 PM Thread Starter
johnlo23
Had a $20 wheel balance done this morning at my local Mavis Tire and noticed a HUGE improvement. There is still a 'loose' feeling at speeds over 50mph, but the side-to-side wobble is gone.
I am going to get an OEM trac bar and see if that makes things better.
Thanks for the advice.
johnlo23 is offline
post #5 of 5 Old 01-31-2012, 05:39 PM Thread Starter
johnlo23
Cleaned the INSIDE of my rims
Just in case anyone reads this thread.
About a month ago when rotating my tires, I decided to thoroughly clean the inside (vehicle side) of my rims. There was a good amount of sludge on the flat parts that wasn't visible from the street side.
So, either I finally got to a rotation that kills the harmonic, or the extra weight from that sludge was throwing off the tire balance enough to cause it.
Anyone having tire vibration troubles may want to try cleaning their rims. Might help.
johnlo23 is offline
death wobble , no lift , shimmy , trac bar , vibration , TJ
Rebuilding a stock Trac-Lok? bruker TJ Wrangler Technical Forum 16 12-03-2012 08:40 PM
Tie Rod and Trac Bar Upgrade Help harlequinreef JK Wrangler Technical Forum 7 02-16-2010 08:04 PM
stock 04 TJ First upgrade - Aussie locker or 3.25 RC lift? Maicol183 TJ Wrangler Technical Forum 14 10-24-2009 11:04 AM
aftermarket trac bar for stock lift? CCJ TJ Wrangler Technical Forum 3 09-09-2009 08:25 AM
trac bars and stock springs jeepmech06791 YJ Wrangler Technical Forum 6 04-22-2007 09:27 PM
