dusty run/air filter - JeepForum.com
 4Likes
post #1 of 31 Old 09-18-2017, 03:34 PM Thread Starter
eddiefast
Did a dusty run yesterday. (Bee Cnyn-SoCal). Less power on hills coming home. 1st check was air filter. Aha! But am I going to need a new one every dust run? Better solutions sought. It was pure as snow 2 days ago.
eddiefast is offline
post #2 of 31 Old 09-18-2017, 03:47 PM
biffgnar
biffgnar's Avatar
That looks like more than just dust, but to your question depending on how bad the dust is filters can become high use items. I've been in desert races where we had to stop by the side of the course during the race to try to clean filters to keep our engine running and pit/chase guys having new ones to change if necessary is standard.
biffgnar is offline
post #3 of 31 Old 09-18-2017, 04:17 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It depends. My TJ is usually in dry dusty SOCAL conditions and my AC-Delco (or Purolator if I couldn't find an AC-Delco) air filter usually responds well to just being thoroughly blown out by the air nozzle on my shop compressor. It's a judgement call where I know if it needs replacing but couldn't describe exactly what my parameters are.
But as Biff noticed, your air filter looks like there's more than dust in it. Perhaps a bit of blowby from your combustion chambers?
Jerry Bransford is online now
post #4 of 31 Old 09-18-2017, 05:09 PM Thread Starter
eddiefast
Blowby? Perhaps from my bunnyhopping and endangering axles et al with purely beginner handling (not handling) serial bumps? Over-revving? Or am I misunderstanding blowby and how oil got there? Also thanks. Never thought about compressor for cleaning on trail/anytime. Big learning curve methink. Thanks to both you and Biff for responding
post #5 of 31 Old 09-18-2017, 05:36 PM
Jerry Bransford
Administrator
Blowby is when a little oil is making it out of the engine into the air intake via the PCV (positive crankcase ventilation) port.
post #6 of 31 Old 09-18-2017, 05:41 PM
biffgnar
biffgnar's Avatar
Been awhile since I ran stock air intake but if I recall correctly the intake horn is at one end of the box and the pipe to the throttle body is on the other end (I think I have an old box on the shelf I could go look at to confirm). Which end of the box was the dark part of the filter oriented to?
biffgnar is offline
post #7 of 31 Old 09-18-2017, 08:56 PM Thread Starter
eddiefast
Thanks and thank heaven for internet so I could find out what a PCV port is. Last car I actually worked on was a 1950 TD (MG) and not so long after 1950. Didn't have much more than a couple SU side drafts and a manual crank. Things have changed. I am just going to abide for the time being and keep watch. Maybe the filter was dirty all along and my peek at it may have been an inadequate inspection. Not to have you being my research source, what is the usual cause of the blowby? No problem if I have used up my welcome and you don't respond.
I am nonetheless appreciative that you and others are so willing to help and teach
post #8 of 31 Old 09-18-2017, 09:25 PM
azzkicker
2007 WK
I don't know how your airbox and PCV are arranged, but I've never had a rig that put the PCV outlet where you could get oil on the pleat side of the filter. Did you have the pleats toward the carb? Did the oil soak through from the flat side?
In any case, I believe the blowby referred to would be oil getting through the PCV valve and making it to your intake. It's a common issue, and one solution is to put an oil catch can in line between the PCV valve and the intake. I just did that on my hemi. The can was about $20 on amazon.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #9 of 31 Old 09-18-2017, 09:32 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Doesn't the TJ have the CCV with a metered orifice (no valve)?...
Knuckelhead is offline
post #10 of 31 Old 09-18-2017, 09:51 PM
Jerry Bransford
Administrator
Edit: In the TJ's case CCV = Closed Crankcase Ventilation. Not valve.
post #11 of 31 Old 09-18-2017, 11:10 PM
Knuckelhead
AFSOC Retired
I found this in the 2000 TJ FSM when I stumbled on it years ago:
CRANKCASE VENTILATION SYSTEM
DESCRIPTION
All 2.5L 4–cylinder and 4.0L 6–cylinder engines
are equipped with a Closed Crankcase Ventilation
(CCV) system (Fig. 4) or (Fig. 5).
OPERATION
The Closed Crankcase Ventilation (CCV) system
performs the same function as a conventional PCV
system, but does not use a vacuum controlled valve.
On 4.0L 6–cylinder engines, a molded vacuum tube
connects manifold vacuum to top of cylinder head
(valve) cover at dash panel end. The vacuum fitting
contains a fixed orifice of a calibrated size. It meters
the amount of crankcase vapors drawn out of the
engine.
On 2.5L 4–cylinder engines, a fitting on drivers
side of cylinder head (valve) cover contains the
metered orifice. It is connected to manifold vacuum.
A fresh air supply CCV tube (hose) from the air
cleaner is connected to front of cylinder head cover
on 4.0L engines. It is connected to rear of cover on
2.5L engines
post #12 of 31 Old 09-19-2017, 03:58 AM
Joe_Fordyce
I took the hose off that runs between the valve cover and the intake and stuck a filter on the stub sticking out of the valve cover. No more oily mist getting into the intake tube.
Joe_Fordyce is offline
post #13 of 31 Old 09-19-2017, 09:46 AM
toximus
At least the late years have a CCV (not a PCV).
OP - If dust continues to be an issue, a snorkel with a prefilter may be worth looking into.
toximus is online now
post #14 of 31 Old 09-19-2017, 09:56 AM
TJnBC
I have just started to smell a bit of oil going up hills towing. I suspect , based on looking at my filter, the same thing is happening, blow-by.
By eliminating that tube between the Intake and VC , did you notice any performance difference?
Thanks in advance.
2006 LJR...the madness begins again
TJnBC is offline
post #15 of 31 Old 09-19-2017, 10:00 AM
NotURMailman
NotURMailman's Avatar
It won't effect your performance.
But, if you have blow-by, an open filter in the end of your CCV hose is going to dribble oil.
TJnBC likes this.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
