Durango steering box - JeepForum.com
post #1 of 9 Old 07-30-2010, 10:45 AM Thread Starter
tim87114
Anyone tried it? I've seen it done, and it's bolt on. It's ironic that it's only $169.00 where as the TJ box is around 300-500 depending on where you look.
Any comments?
tim87114 is offline
post #2 of 9 Old 08-10-2010, 04:45 PM
cpleasant
cpleasant's Avatar
Any comments?
Where did you find it for $169?
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #3 of 9 Old 08-10-2010, 04:49 PM
Kenbo-Slice
One of the best mods I have done. It is GREAT!
Get a Durango box from a 98 with a 318 V8 (if im not mistaken) WITHOUT the snowplow package!
Jeep build up...ONGOING
Kenbo-Slice is offline
post #4 of 9 Old 08-10-2010, 05:20 PM
cpleasant
cpleasant's Avatar
I could have swore I heard people say get the snow plow option. How different is the box?
On a side note, are you the monster in the picture?
post #5 of 9 Old 08-10-2010, 05:36 PM
DstroyrOfWrldz
forgive my ignorance, but what is the advantage of the durango box over the stock Jeep one?
Joe
1999 Wrangler Sahara
2005 Wrangler Unlimited (Sold 9/2012)
DstroyrOfWrldz is offline
post #6 of 9 Old 08-10-2010, 05:48 PM
matthewh_1
I believe it's only bolt-on for 2002 and older TJ's
National Topless Day 2010 winner!
Zombie Outbreak Response Unit #70
Originally Posted by jclauson View Post
When a girl tells you your flex is sexy then you are doing something right in life.
matthewh_1 is offline
post #7 of 9 Old 08-10-2010, 06:21 PM
Kenbo-Slice
Same box other than the snowplow option requires more turns lock to lock.
Yes, my avatar is me along with my trusty Jeep pulling dually.
No ignorance.... The advantage is that the Durango box has a larger piston inside of the box (moves more fluid) and requires fewer turns lock to lock (turns of the steering wheel to max out) than the stock TJ steering box.
**** Double check the 2002 + older comment. That may be true and I forgot about it!***
post #8 of 9 Old 08-10-2010, 06:24 PM
Benderff
Benderff's Avatar
Any comments?
Make sure you priced the correct box. 03-06 Tjs take a little more work. You will find a ton of "comments" when you try a search. It's been done a lot.
http://www.jeepforum.com/forum/f9/du...3-06-a-816687/
Benderff is offline
post #9 of 9 Old 08-10-2010, 07:49 PM
98blacksahara
1951 CJ3A
I got the plow package one. Works great, very strong. I had to upgrade to v8 zj steering as I kept bending the small TJ cross bar. now either the jeep moves or whatever its up against moves
Originally Posted by RubiconRazorbac View Post
Well, I've never eaten a turd sandwich, but I wouldn't have a problem recommending not to try it.:thumbsup:
But I'm sure someone out there will post that they regularly eat turd sandwiches with no problems...
98blacksahara is offline
durango , tj , wrangler , steering box , swap
Replacing jeep steering box with a Durango Steering box? Beefstew TJ Wrangler Technical Forum 171 05-22-2012 08:17 AM
durango steering. 99 durango 00 tj pitman arm slafferty TJ Wrangler Technical Forum 0 09-05-2009 01:28 PM
Durango steering box is in... badoosh27 TJ Wrangler Technical Forum 12 09-14-2008 10:38 PM
Will durango steering pump work with the steering box. sitdwnandhngon YJ Wrangler Technical Forum 0 08-13-2008 07:20 PM
Durango steering box demoguru YJ Wrangler Technical Forum 18 02-26-2007 09:57 PM
