durango steering. 99 durango 00 tj pitman arm - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > durango steering. 99 durango 00 tj pitman arm
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 09-05-2009, 01:28 PM   #1
slafferty
I picked up a 99 durango steering box and I was wondering if i could use the pitman arm that is already on the durango box. it looks the same as the one on my tj.
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered[QUOTE=RUBtjICON;9622056]If you arent scratching it, you arent trying hard enough :tea:[/QUOTE]
[U][I][B]MY BUILD THREAD[/B][/I][/U]
[URL="http://www.jeepforum.com/forum/f22/slaffertys-2000-tj-build-1121555/index2.html"][COLOR="RoyalBlue"][SIZE="4"]http://www.jeepforum.com/forum/f22/slaffertys-2000-tj-build-1121555/index2.html[/SIZE][/COLOR][/URL]
slafferty is offline   Reply With Quote
