Durango Alternator Swap with pictures! - Page 6 - JeepForum.com
post #76 of 152 Old 11-04-2011, 04:53 PM
tshuelsman
1978 CJ7
Just to confirm this will work with a 4.0? I've only seen the 2.5l referenced.
In God we Trust.
tshuelsman is offline
post #77 of 152 Old 11-04-2011, 05:04 PM
LimeLJ
LimeLJ's Avatar
Ah... I had never seen it referenced working on the 2.5L. Yes, it does work on the 4.0L.
LimeLJ is online now
post #78 of 152 Old 12-27-2011, 08:23 PM
tiburonimbus
is this confirmed to work on a 2.5l?
I've got to get it outta the parking lot it is stuck in tomorrow - and an upgrade instead of a stock replacement is always ok by me
They waited, and watched.
Gennaro drummed his fingers on the dashboard. "What are we waiting for?"
Muldoon didn't answer immediately. "The rex is out there somewhere," he said, squinting at the landscape in the morning sun. "And we don't have any weapons worth a damn."
"We're in a Jeep"
tiburonimbus is offline
post #79 of 152 Old 03-08-2012, 08:53 PM
mogo116
so its been while since this thread was started but just to confirm the 136amp will bolt on to my 98 4.0 with out a problem i should just upgrade the wiring? hows everyones doing now a days?
mogo116 is offline
post #80 of 152 Old 12-31-2012, 04:53 PM
kjmccar
Just stopped my my local oriley's and picked up one of these alternators. Installation supper easy, but I noticed that my belt is now very tight (larger alternator?) The little tentioning wheel is almost all the way pressed back just under normal use. My idle speed also rose about 200rpm after the upgrade. Is that normal? Or is the belt to tight? Should I get a larger belt to accommodate the new alternator?
I would also like to know if it is reccomended to upgrade the stock 8awg wire to something more like 4awg, or even 2awg.
Thank you!
kjmccar is offline
post #81 of 152 Old 12-31-2012, 06:11 PM
KeyserGogo
I installed a 136 amp unit I picked up from advanced auto for a 98 dakota on my 98 4.0 about 2 weeks ago. The stocker finally crapped out on me. Fit just like the stock one... and now my dome light doesn't flicker when my seat heaters are on. Guess she needed the extra juice. I was too lazy to swap the pully, the belt just rides towards the back of the pulley with no problem. Didn't notice an rpm change or belt tensioner problems kjmccar - not sure if we have the same tensioning mechanism though. The wiring only needs to change if you are using accessories that require the full output of the alternator... it doesn;t put out 136 amps all the time, it puts out the load that is called for.
Green 1998 Sahara
KeyserGogo is offline
post #82 of 152 Old 02-07-2013, 04:21 AM
binnsmark
Originally Posted by timberwolf0122 View Post
So I finally got round to swapping out my boring old stock alternator (LJ 2005) for a sexy new(used) 160Amp Alternator from a 2002 Durango.
The stock alternator is on the left and the durangolt's is on the left, despite the size difference it is a direct bolt in replacement.
Safety 1st, safety 2nd, I disconnected the +ve lead from the battery and secured it out the way with the battery tie down, now my only danger was the scorching sun.
I had replaced the stock battery 2 days ago for a Bond platinum 34/78 (1090 CCA! for under $100), which is why it is the only clean thing under the hood.
With the power disconnected I removed the alternators 2 wire plug and the power cable that leads from the alternator to the +ve battery terminal
Time to take the fan belt off, I'm glad I put a flexilite fan in, now I have room to work!
The tensioner has a 1/2" socket so it is a peice of cake to release the tension with a socket wrench and slip the belt off the idler.
Undoing the two bolts (15mm) that held the stock alternator was the hardest part of the job (they were on good), it took 20 minutes of cursing and soaking in PB blaster be they relented.
A further 10 minutes of cursing ensued as I tried to get the new alternator to fit on to the mounting bracket, it would almost go but I could not get the bolt through....
Then I noticed this, the bottom mount has a sort of nut-sert thing on it that held the bolts thread and it was stick out on the inside too far!, 30 seconds later I had tapped it out all of 1/16" and bingo! everything lined up!
I tightened everything down good an solid reattached the cables to the new alternator and the battery, re-fed the fan belt, then with crossed fingers jumped into the cab and started her up.
It's always a good feeling when not only does the engine start but it runs and there are no loud bangs or screeches. :-)
I've done a couple of tests with the 1500W inverter running an 800W drill and I can run it alot longer and harder before the voltage drop alarm goes off!
Comming soon(ish) Dual battery install write up and a winch install!
This is good... Read a lot about guys doing it on the older TJ's... but seeing as you did it on an 05, I know it will work on my 06!
binnsmark is offline
post #83 of 152 Old 02-14-2013, 02:42 PM
02ws666
Originally Posted by Guardian7 View Post
(136A Alternator from 97-98 ZJ, Dakota, Durango, Ram (PN:56027913) fits 97-03 Wrangler)
(0406 Durango with 4.7/160A (PN:56029914AA), fits 04-06 Wrangler)
Does this mean that Since I have a 2003 TJ, I will have to upgrade to the 136a? What is my stock alternator rated at? Need to do this swap and its a real headache to read and understand all of the what ifs.
2003 Wrangler - Light Khaki Metallic - 4.0 w/ nv3550, Smittybilt Stinger, Warn M8000 Winch, 4 Hybrid lift, G2 Dana 44s w/ 4.56 and E-Locker in front 30 spline, Detroit in rear 33 spline, 33x12.5 KM2s
02ws666 is offline
post #84 of 152 Old 02-14-2013, 02:58 PM
mike_dippert
mike_dippert's Avatar
stock is 117 amp peak, 19 amps isn't worth upgrading unless you NEED a replacement or you're getting low voltage alarms.
mike_dippert is offline
post #85 of 152 Old 02-14-2013, 03:04 PM
02ws666
Just putting it out there, I found a specific write up for a I6 2003 TJ like mine. Here for the record. Hope it helps someone. a 160 amp will fit a 03, jus tneed to upgrade wiring
http://www.wranglerforum.com/f5/160-...ion-74732.html
02ws666 is offline
post #86 of 152 Old 02-14-2013, 03:33 PM
02ws666
My only other question, is does the advanced auto alternator fit a 2003?
http://shop.advanceautoparts.com/web...ide_19850389-p
02ws666 is offline
post #87 of 152 Old 02-18-2013, 11:27 PM
02ws666
Wanted to give an update on my specific jeep. 2003 wrangler. The 160 amp fit like a glove and can be had from autozone for cheaper then advanced auto after the core. And my local store had one laying around. Wanted to update because I, like many others, try to find a specific example of a certain year model. Well here it is. It works just fine. Thanks everyone
http://www.autozone.com/autozone/par...90_23521_4453_
02ws666 is offline
post #88 of 152 Old 02-20-2013, 12:38 AM
bbradUSMC
Tagging this for later reference. Thanks guys.
bbradUSMC is offline
post #89 of 152 Old 03-15-2013, 10:32 AM
rusty762
Looks like a simple and worthy upgrade!
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #90 of 152 Old 03-15-2013, 06:29 PM
ericxj1999
I'm running one from a 2007 Chrysler aspen on my 2000 tj 2.5 160a no modification paid 30 at the junk yard I'm pretty sure is stock on liberty as well
ericxj1999 is offline
dodge , durango , alternator , swap , tj , wrangler
Durango 160 amp alternator to 06 TJ swap N8Doggz TJ Wrangler Technical Forum 56 06-22-2011 03:20 PM
02 Durango 5.9L Alternator in a 01'? TJamz TJ Wrangler Technical Forum 2 07-20-2010 08:13 AM
TJ/Durango steering box swap DBraceM20 TJ Wrangler Technical Forum 5 11-25-2006 01:59 PM
Durango Alternator Thug Nasty TJ Wrangler Technical Forum 5 09-13-2006 06:00 PM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 03:30 PM
