Durango Alternator Swap with pictures! - Page 5 - JeepForum.com
 1Likes
post #61 of 152 Old 06-01-2011, 04:56 PM
silver97tj
silver97tj's Avatar
Hi all
I got a rewound 136A on ebay and it fit my TJ 2.5 fine. Thing is I cant find oe part number on it the seller says it will both 4.0 and 2.5? it fit mine fine and is running good........................................
PS it looks just like one i took off, no arm to cut off, my lights are brighter.... it came with paper showing graph of amp test
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #62 of 152 Old 06-02-2011, 01:35 AM
bojang
Not all of them will have an arm to cut off. There are I think four different variations of mount locations, 97-99, 2000, 01-03, 04-06.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #63 of 152 Old 06-21-2011, 11:42 AM
pladead
I did the 2002 Durango Duralast (160A) alternator swap. Direct bolt-in. I did have to change the seven grove pulley back to the stock six grove. The channels in the seven grove were too deep and they wore through a brand new belt in about an hour of running.
And yes, I did upgrade the wires.
pladead is offline
post #64 of 152 Old 06-21-2011, 09:01 PM
Ajamant
Just dropped a 04 durango 160amp alternator into 04 TJ and replaced the belt while I was at it. No issues, didn't have to cut off arm with 1/8 inch clearance around sparky cover. Finally blew the stock alternator after successfully winching a f350 diesel on 37's outta a nasty whole (superwinch still pulling strong).
WIRING QUESTION: So the consensus for the beefed up wiring is taking 2-4 gauge wire and running a parallel circuit to the battery??? Confused on where to run the parallel wire.
04 TJ/3" OME/1" MML/1"BBL/3/4" coil spacers up front/discos/Extended bump stops/adj. Rear track bar/hi-lift/ 33x10.5x15 toyo MT on steelies/Epi9000superwinch/nates front bumper/160amp alternator
06KJ CRD with GDE eco tune/samco's/fumoto/tow package/brake controller
Ajamant is offline
post #65 of 152 Old 06-22-2011, 07:46 AM
pladead
I completely removed the stock wire.
- 2 AWG wire to the starter
- 4 AWG wire to the alternator with an in-line Mega Fuse (175A)
- used marine type terminals at the battery
- I crimped the 2 and 4 wires together into one eyelet at the battery end
- You have to leave the positive wire to the under hood fuse box intact
Any battery shop can crimp the wires.
I also upgraded all my winch wires with 1 AWG
Mine is a 1999 TJ with a 2002 Durango 160A altanator so yours may be different.
pladead is offline
post #66 of 152 Old 06-22-2011, 09:22 AM
Ajamant
Thanks for the info, but I'm fairly sure (not looking at it now) that the 04TJ only has 1 wire going into the fuse box. Will confirm tonight.
Didn't even think about upgrading winch wiring. Is something that's needed, I have a superwinch epi9000 with beefy wiring already, dint know what gauge.
Ajamant is offline
post #67 of 152 Old 06-22-2011, 11:05 AM
pladead
Mine only has one wire to the box also...
The wire coming out of the box should be the one to the alternator. This is the wire I replaced.
The one wire from the battery to the box is the power for the box.
Instead of running from the box to the alternator I ran mine from the battery to the alt with a 175A in-line fuse.
I may have confused things by bringing up the starter wire upgrage also.
pladead is offline
post #68 of 152 Old 06-22-2011, 11:49 AM
Ajamant
Okay, thank u for the follow up. Can I just leave the stock wiring alone and run a single 4g wire with 175amp fuse from the alternator to the battery?
Electrical isn't my strong suit.... My next task is a hand throttle because Stu's write up on the cool throttle winch control via your cruise control was WAY to much wiring. I'll stick with some bike parts and call her good ).
Ajamant is offline
post #69 of 152 Old 06-22-2011, 01:07 PM
Ajamant
Ajamant is offline
post #70 of 152 Old 06-22-2011, 01:57 PM
pladead
I don't think that would be a problem. The only issue I see would be now you would have a 175A in-line fuse and the stock fusible link (small piece of wire acting as a fuse).
You might want to ask someone a little more knowledgeable than me.
pladead is offline
post #71 of 152 Old 06-22-2011, 06:06 PM
Ajamant
Just found this link in the electrical section: their use is for stereo equipment but the concept is sound. It's called "The Big 3" and there's a decent write-up here:
http://www.the12volt.com/installbay/...TID=73496&PN=1
Ajamant is offline
post #72 of 152 Old 06-22-2011, 06:47 PM
Swacos_tj
yea the big 3 a must with high current systems
Swacos_tj is offline
post #73 of 152 Old 08-10-2011, 01:54 PM
kittyhawk
Originally Posted by EaglesSJ View Post
WorldwideAlternator
Part No 12328
Advance Auto Parts: Alternator by Worldwide - Part 12328
remember though its only online. then you can select pick up in store if it is in stock at your local place. I had to wait for shipping cause mine wasnt. They also have a deal out now where if you spend 100 you get 50 back on a gift card. good deal i think!
Any issues with this Alternator??? I was going to get one but I am worried about it being a reman.
Thanks
Dave
kittyhawk is offline
post #74 of 152 Old 08-10-2011, 07:14 PM
F9K9
F9K9's Avatar
Thanks
Dave
Zero! Over two years on mine with scores of heavy winch sessions with a Warn 8274. Just my 2Ę
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #75 of 152 Old 09-30-2011, 07:04 PM
LimeLJ
LimeLJ's Avatar
Just installed one of these today. Lost the alternator on the way home from work and drove to Advance Auto Parts in the morning. Swapped it in the parking lot in about thirty minutes. Only fitment issue was I needed to file the bottom rear nut insert. Need to get a proper fuse setup in there now.
LimeLJ is offline
dodge , durango , alternator , swap , tj , wrangler
Durango 160 amp alternator to 06 TJ swap N8Doggz TJ Wrangler Technical Forum 56 06-22-2011 03:20 PM
02 Durango 5.9L Alternator in a 01'? TJamz TJ Wrangler Technical Forum 2 07-20-2010 08:13 AM
TJ/Durango steering box swap DBraceM20 TJ Wrangler Technical Forum 5 11-25-2006 01:59 PM
Durango Alternator Thug Nasty TJ Wrangler Technical Forum 5 09-13-2006 06:00 PM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 03:30 PM
