Durango Alternator Swap with pictures! - Page 10 - JeepForum.com
 1Likes
post #136 of 152 Old 03-27-2014, 08:15 AM
D0T-C0M
2014 JK Wrangler
Electrically it makes no difference if they had connected the end of the fusible link coming from the alternator to the battery positive post. They probably wanted to have less wires as possible going to the battery.
BTW the starter wire doesn't need to be changed but it doesn't hurt. It is not affected by the increase in alternator current.
D0T-C0M is offline
post #137 of 152 Old 03-27-2014, 08:19 AM
Ironhead
Originally Posted by D0T-C0M View Post
electrically it makes no difference if they had connected the end of the fusible link coming from the alternator to the battery positive post. They probably wanted to have less wires as possible going to the battery.
thats all i could think of too
Ironhead is online now
post #138 of 152 Old 03-27-2014, 08:31 AM
D0T-C0M
2014 JK Wrangler
This is a very important and potentially dangerous mod if not done correctly. Just imagine someone with dual 1000 cranking amp batteries, you could have 2000 amps flowing into a faulted alternator. That's some serious current. People don't realize that the fusible link isn't sized to blow at a certain amperage. Its function is to run cool at max alternator current but under short circuit conditions where the fault current is 3 or 4 times that max alternator current its designed to melt. If you run a 10AWG designed for a (117-130a) alternator than it will run hotter and probably beyond the conductor's rated temperature rise spec which can lead to insulation failure over time as it becomes brittle. That is why you also need to increase the fusible link to 8AWG for a 150-190 amp alternator.
D0T-C0M is offline
post #139 of 152 Old 03-27-2014, 09:21 AM
bbradUSMC
Thank you both for this discussion. I have been following yall and have learned a lot. I have been wanting to do this mod for some time to compensate for my winch but wasn't sure how to actually upgrade my harness.
Live Free,
Brad
bbradUSMC is offline
post #140 of 152 Old 03-27-2014, 09:50 AM
BYuen
BYuen's Avatar
What length of the 8 gauge fusible link should you use, just match it to the factory 10 gauge link? And you just solder the fusible link to the main 4 gauge wire, correct?
My alternator was making death noises so I recently replaced it with the Durango. Still running the stock wiring for now, but wanted to upgrade it the correct way.
Originally Posted by bbradUSMC
Thank you both for this discussion. I have been following yall and have learned a lot. I have been wanting to do this mod for some time to compensate for my winch but wasn't sure how to actually upgrade my harness. Live Free, Brad
I agree! I know very little when it comes to electrical.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #141 of 152 Old 03-27-2014, 10:30 AM
D0T-C0M
2014 JK Wrangler
Use the same length of fusible link as the 10AWG had and the fusible link needs to be cross crimped (one wire over the other, not end to end) not soldered as the solder has a lower melting point than the copper wire. After crimping use a shrink tube to insulate just the crimp and overlapping about an inch or so on each side. It might be easier just to rob the wiring off a scraped Jeep Libery or durango as I haven't been successful finding a supplier that will sell under a reel of fusible link wire. Anyone have any links?
D0T-C0M is offline
post #142 of 152 Old 03-27-2014, 04:53 PM
BYuen
BYuen's Avatar
Thank you for all the info. I see that $70 reel of 25 ft fusible link, but no one readily sells smaller pieces. Just might be easier to go the jy route as you mentioned. However, I did find these two links. I haven't tried them before though.
http://www.awcwire.com/part.aspx?partname=j156-awg8
http://www.whiteproducts.com/fusible-service.shtml
2001 White TJ Sport
BYuen is offline
post #143 of 152 Old 03-27-2014, 06:29 PM
D0T-C0M
2014 JK Wrangler
Yeah I emailed the companies in the both links yesterday and haven't heard back from them. It would be helpful for everyone if we had a supplier for these links as many people are upgrading their alternators.
D0T-C0M is offline
post #144 of 152 Old 03-27-2014, 08:06 PM
Mezeron
Do we have a confirmation that this will work on a TJ sport 4.0L that predates 00?? This seems like a great idea for an upgrade but after reading this and doing a bit of searching I cannot find a definite answer. If you can do this is the durango 01-06 still the donor @160amps?
Mezeron is offline
post #145 of 152 Old 03-28-2014, 05:39 AM
D0T-C0M
2014 JK Wrangler
How many wires on the alternator plug on your 97? I didn't specifically research that but seems to me I read something about the voltage regulator being internal to the alternator on the older models. Regardless of the plug in or if the regulator is in the alternator, All that would be requires is to install an external voltage regulator which is pretty simple and get a new plug-in if its different. Its doable just a little more work. I am pretty sure the alternator bolts in but don't quote me on it
D0T-C0M is offline
post #146 of 152 Old 02-13-2016, 11:19 PM
raif281
bump
raif281 is offline
post #147 of 152 Old 02-14-2016, 04:23 AM
D0T-C0M
2014 JK Wrangler
raif281 why the bump buddy? Did you need more information?
D0T-C0M is offline
post #148 of 152 Old 02-14-2016, 07:28 PM
raif281
nahh bud I was reading it through link off the internet. so I bumped it so it would show up in my subscribed and I can read it later as I believe my alternator is going out.
raif281 is offline
post #149 of 152 Old 02-14-2016, 07:45 PM
mukluk
In case anybody else doesn't know, you can subscribe to a thread without responding to it. On the actual website, open the "Thread Tools" tab (located just below and to the right of the Crawl This Thread button), then click on "Subscribe to this Thread". In the JeepForum App, tap the icon in the upper right that looks like a box with an arrow coming out of it, a popup menu will then offer a button choice for "Subscribe to Thread".
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #150 of 152 Old 02-14-2016, 08:15 PM
raif281
tried that before and it doesn't show up on the app under subscribed unless someone comments on it. which is why I commented on it
raif281 is offline
dodge , durango , alternator , swap , tj , wrangler
Durango 160 amp alternator to 06 TJ swap N8Doggz TJ Wrangler Technical Forum 56 06-22-2011 03:20 PM
02 Durango 5.9L Alternator in a 01'? TJamz TJ Wrangler Technical Forum 2 07-20-2010 08:13 AM
TJ/Durango steering box swap DBraceM20 TJ Wrangler Technical Forum 5 11-25-2006 01:59 PM
Durango Alternator Thug Nasty TJ Wrangler Technical Forum 5 09-13-2006 06:00 PM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 03:30 PM
