Durango 160 amp alternator to 06 TJ swap - Page 4 - JeepForum.com
post #46 of 57 Old 01-21-2010, 09:47 PM
dbbd1
dbbd1's Avatar
My '03 took a 160amp from autozone (rebuilt by worldwide) with a part number of 12328. That was autozones and worldwides number.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #47 of 57 Old 07-17-2010, 09:10 AM
TJinSoFLA
I have an 2001 TJ Sport. Does the '02 5.9L Durango Alernator bolt in and wire up directly? Or are there some other mods needed?
TJinSoFLA is offline
post #48 of 57 Old 07-18-2010, 09:06 AM
khill8469
i just put my 160 amp alternator in from an 04 Durango with a 4.7 I decied to cut off the extra arm. My question is if it dies will i have truble using it as a core?
khill8469 is offline
post #49 of 57 Old 07-19-2010, 09:38 AM
nmj48
depends on how nice your cut looks. the parts guy probably won't even notice. if it dies you could always get a rebuild kit for it, or take it to an alternator place to have it rebuilt
nmj48 is offline
post #50 of 57 Old 07-19-2010, 10:16 AM
TJinSoFLA
I just did the upgrade over the weekend. I have an '01. I got the alternator from an '02 4.7 Durango. I gave back the stock alternator as the core and they didn't even look at it. The new one was very easy to install. Just ground about an eight inch off the inside of one of the bottom arms and left the extra top arm on.
post #51 of 57 Old 07-25-2010, 10:48 PM
2003X
I think there is some confusing information on this thread. I have been trying to gather research for my 03TJ on what 160 amp alternator will work.
I just want to know what dodge durango amp I need to ask for that is a direct bolt in to my 03TJ. Any help is greatly appreciated.
What does this mean? I just go to Auto Zoo and this part # is a direct bolt in to my 03 TJ?
Is this true?
So to recap, a 2004 Durango 4.7L 160amp alternator is a direct bolt on to a 2000-06 TJ 4.0L. Same mounts & same pulley grooves. Cool beans, I'll add that to my upgrade list.
My Build
2003X is offline
post #52 of 57 Old 07-26-2010, 08:29 AM
2003X
I called Auto Zone today and gave them part #12328, it came up in the computer as 2004 Durango 4.7L 160amp alternator. It was $119 + $60core, so $179 total. I believe it is rebuilt.
I am going to call some local recycling yards and see if I can get one cheaper.
My Build
2003X is offline
post #53 of 57 Old 07-27-2010, 01:50 AM
bojang
Pretty sure that is the one I have in mine now. If you do use it, test fit to find out if you have to cut off the extra arm. I didn't have to, I have 1/8 inch clearance around the coil pack. That is the only issue that you should have with it.
As far as the core, I gave them my old one, and they never opened up the box.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #54 of 57 Old 08-18-2010, 09:14 AM
2003X
Could you post a pic of the alternator in the hooked up?
My Build
2003X is offline
post #55 of 57 Old 08-18-2010, 10:02 AM
timberwolf0122
Here's my 160 Amp Durango swap I did a few weeks back
http://www.jeepforum.com/forum/f9/du...tures-1063518/
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is online now
post #56 of 57 Old 06-22-2011, 03:03 PM
Ajamant
Just put the 2004 Durango 4.7 160amp alternator into an 04TJ with no issues, no removal of arm with clearance around coil pack.
04 TJ/3" OME/1" MML/1"BBL/3/4" coil spacers up front/discos/Extended bump stops/adj. Rear track bar/hi-lift/ 33x10.5x15 toyo MT on steelies/Epi9000superwinch/nates front bumper/160amp alternator
06KJ CRD with GDE eco tune/samco's/fumoto/tow package/brake controller
Ajamant is offline
post #57 of 57 Old 06-22-2011, 04:20 PM
chubbena
Would a smaller pulley on the alternator help eliminating the need for fast idle? Does such pulley exist and have anyone tried? Thanks
chubbena is offline
02 Durango 5.9L Alternator in a 01'? TJamz TJ Wrangler Technical Forum 2 07-20-2010 09:13 AM
Durango swap complete. Marine_Mike YJ Wrangler Technical Forum 8 06-17-2008 06:31 PM
Durango seat swap... Dom45ACP TJ Wrangler Technical Forum 1 06-12-2007 07:42 PM
Durango Alternator Thug Nasty TJ Wrangler Technical Forum 5 09-13-2006 07:00 PM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 04:30 PM
