Durango 160 amp alternator to 06 TJ swap - Page 3 - JeepForum.com
post #31 of 57 Old 10-29-2009, 08:44 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
interesting... very interesting.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #32 of 57 Old 10-30-2009, 11:02 AM
mike_dippert
mike_dippert's Avatar
Originally Posted by F9K9 View Post
I really don't know, Bro. I would suspect so but, can't tell you that. I would recommend a search on ROF.com under the TJ section. BTW, they are very non Rubi friendly.
Semper Fi
no they aren't. i've been over there for 3 years w/o a rubi. But the forum (as it's name implies) is intended for rubi's. Don't expect to get much out of them if you're asking a tech question that doesn't pertain to something that came on a rubi.
All 03-06 TJ's w/ a 4.0L are the same under the hood, so you can get good tech there about this.
Just don't ask about front D30's, NP231's or a trans that didn't come in the rubi.
http://<a href="http://tinyurl.com/y...om/ydm42k6</a>
a link to a ROF topic about a 160A swap into a '04. He had some issues but posted a fix at the bottom. I'm about to bump it for long-term (4.5 months now) results.
mike_dippert is offline
post #33 of 57 Old 11-10-2009, 09:14 PM
dbbd1
dbbd1's Avatar
What changed in the 03's? I got all excited about this. I went out and found a 139a from a durango, numbers matched but it did not fit. The number on the alt is 5602-7913 but the number on mine is 56041-864AB. Also, the mount points on the duranago one are basically at 12 and 6, the mounts on mine are like 12 and 7. The other number on mine is TN 121000-3821. Is this upgrade no-good for '03 and above? And more, there was a diode (rectifier) pack on the durango alt but on mine it seems to be built in. Mine looks like Snatchblock's up above (though I swear the mounts are a little off on mine, like I said) and the durango's looks like posts in other threads on this mod. I would like to upgrade but do not need the 160a (yet) and would just like to do the 136a. Although, if someone had the part number and the "TN" number I might still try to find a 160a in a junkyard.
Help!
Thanks!
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #34 of 57 Old 11-10-2009, 09:23 PM
dbbd1
dbbd1's Avatar
Maybe Pirate has a thread on this but, do we need a direct "plug n play" thread?
Mine is an '03 TJ. A '98 Durango's V-8's 160 amp is a direct fit on my '03. No counting grooves, belt or pulley changes.
Do you have any part/label numbers off of the 160a you have?
-John Wayne
dbbd1 is offline
post #35 of 57 Old 11-11-2009, 08:06 AM
JeepRocks86
so i'm looking at autozone.com and all they are showing is a 136amp alt for the 98 durango
They do have a 160 amp from the 02 4.7 durango though.
am I missing something?
For Sale:
post #36 of 57 Old 11-11-2009, 09:55 AM
mike_dippert
Try a '98 V8 Durango.
post #37 of 57 Old 11-11-2009, 12:01 PM
SpeedJeep
SpeedJeep's Avatar
Here's something for you guys driving a 2000 TJ. I followed this advice and got a direct bolt in, 160 amp alternator at the junkyard. (I'm WhiteTJ on that board)
2000 TJ 4.0L Alternators: One year only? - JeepsUnlimited.com Forums
SpeedJeep is offline
post #38 of 57 Old 11-11-2009, 01:11 PM
F9K9
F9K9's Avatar
My bad, it is not a '98 but, an '04
Here it is for $139 atr advance.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #39 of 57 Old 11-11-2009, 01:31 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
So to recap, a 2004 Durango 4.7L 160amp alternator is a direct bolt on to a 2000-06 TJ 4.0L. Same mounts & same pulley grooves. Cool beans, I'll add that to my upgrade list.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #40 of 57 Old 11-11-2009, 03:11 PM
Rescue06
Rescue06's Avatar
I will have to get one also.
Rescue06 is offline
post #41 of 57 Old 11-11-2009, 03:23 PM
F9K9
F9K9's Avatar
I made a mistake before so, I don't want to say that is an absolute. It worked on my '03. A lot of changes were made in '03 from the '02s. I went through my receipts and couldn't find mine for the alt. I do have a web account at Advance and I logged into it. I had a fictitious vehicle on my account as an '04 Durango V-8. I looked up the alt part #s for it and compared the part numbers to what is residing under my hood. That being said, I have heard that Rubis came with an upgraded alt and that may be where the pulley grove differences are coming from.
F9K9 is offline
post #42 of 57 Old 11-11-2009, 03:26 PM
Unlimited04
The upgraded alternator may have been an option on some models, and standard on others. I know LJ's came with the 117 amp upgraded alternator, I've got one.
Useful Write-Ups:
Funny:
post #43 of 57 Old 11-11-2009, 08:59 PM
dbbd1
dbbd1's Avatar
Yup, that is what mine looks like (only without the 4th arm/mount). But if I go with the 160a, a wiring upgrade should be in order too, right?
-John Wayne
dbbd1 is offline
post #44 of 57 Old 11-12-2009, 07:45 PM
F9K9
F9K9's Avatar
I haven't had any issues yet but, that I haven't had any long hard pulls since the upgrade.
F9K9 is offline
post #45 of 57 Old 11-27-2009, 07:27 AM
BigBlackTJ2010
BigBlackTJ2010 is offline
02 Durango 5.9L Alternator in a 01'? TJamz TJ Wrangler Technical Forum 2 07-20-2010 08:13 AM
Durango swap complete. Marine_Mike YJ Wrangler Technical Forum 8 06-17-2008 05:31 PM
Durango seat swap... Dom45ACP TJ Wrangler Technical Forum 1 06-12-2007 06:42 PM
Durango Alternator Thug Nasty TJ Wrangler Technical Forum 5 09-13-2006 06:00 PM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 03:30 PM
