Duplicate key - JeepForum.com
post #1 of 22 Old 11-23-2007, 08:50 AM Thread Starter
shw104
Duplicate key
I lost my spare key and now only have one. I have a 2005 Wrangler... Do I have any options besides going to the dealer to have a new key made/programmed? As I understand it, since I only have one key, my options are limited.
Thank you!
Scott
shw104 is offline
post #2 of 22 Old 11-23-2007, 08:52 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
I always have my spare keys made up at Lowes
TheBoogieman is offline
post #3 of 22 Old 11-23-2007, 08:56 AM
04 Unlimited
04 Unlimited's Avatar
2015 JK Wrangler
Yep, you need two keys to program the third. At least that's the routine with my 04. You might check the owner's manual.
2015 JK Unlimited, White, Auto
RIP LJ
04 Unlimited is offline
post #4 of 22 Old 11-23-2007, 10:42 AM
W0JON
depends if you have the security option... I have a 2005 unlimited and I can use a standard key made at the local hardware store... might be worth spending a dollar and have a key made and try it... or look on your options and see if you do have the security option...... even if it does not allow you to run your rig, you would have a spare to at least open the door locks....
W0JON is offline
post #5 of 22 Old 11-23-2007, 10:49 AM
belzurkur
Thank you!
Scott
I was in the same boat, only one Sentry key. When I was looking for non-dealer solutions, one suggestion was to cut the fob from the Sentry key and place it inside the plastic ignition cover.
Now you could use standard keys, but your anti-theft is gone.
I didn't go that route, but I thought it was creative.
belzurkur is offline
post #6 of 22 Old 11-23-2007, 01:23 PM
BozoWise
BozoWise's Avatar
For 30cents you can install a resistor and bypass the sentry. I've done it many times for remote starts and cheap customers not wanting to buy another sentry key.
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
post #7 of 22 Old 11-23-2007, 01:46 PM
Brian P
That will only work with older systems (like GM's chipped key). The Chrysler Sentry System controller needs to "see" the unique code sent to it by the key to allow the fuel injectors to fire.
To the OP, if you have the Sentry System (gray headed key, not black) you may be able to get one at a full-service locksmith that does a lot of lock-out work. They have the blanks and tool to program your Jeep (yes, it's the Jeep that gets programmed, not the key.) For those of you who will yell, "No locksmith will have a DRBII tool" you're right, they don't. But, the makers of the Sentry System do sell licensed locksmiths the module that does just the key (vehicle) programming.
Brian Phillips
05 Unlimited
Brian Phillips
05 Unlimited
Brian P is offline
post #8 of 22 Old 11-23-2007, 02:18 PM
kehoe
what year did the sentry keys start? I have an 04 with a grey headed key but I do not believe it is sentry... is there anyway I can find out (sorry to thread highjack)
kehoe is offline
post #9 of 22 Old 11-23-2007, 05:22 PM
Davejb
The gray keys are usually sentry, the black ones are not, for the most part.
2006 Wrangler Unlimited
Vote Quimby
Davejb is offline
post #10 of 22 Old 11-23-2007, 05:39 PM
2jhanna
i have a `02 with the sentry system and the gray key. the owner's manual states that you must have two keys to program additional keys (i think a total of 8 is allowed). if you don't have 2, then the manual states that a dealer can do it.
we have an `98 explorer with the same set-up. a went ahead and had a third key made.
jhanna
denton county, tx
2jhanna is offline
post #11 of 22 Old 11-23-2007, 06:59 PM
gnfreak
just got a 2004 tj and didnt know if i had sentry for sure so i went to the dealer and the parts guy printed out my option sheet. it has the sentry (GXX) and i only have one key. i gotta spend a little more money....oh well
gnfreak is offline
post #12 of 22 Old 11-23-2007, 07:02 PM
joe's_yj
joe's_yj's Avatar
get it cut my the dealer, if you have one with out the responder in it you can only start the car 3 times before it wont let you anymore
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #13 of 22 Old 11-24-2007, 02:48 AM
sryan2k1
That is completely wrong.
If the key is black you don't have the sentry module and you can get a copy made anywhere, if the key cover is grey you have the module, and without two you need a dealer (or someone with a DRBII/III or a service unit for the sentry module) to reprogram the unit for the new keys.
A key that the module doesn't know will NOT start the engine, ever.
sryan2k1 is offline
post #14 of 22 Old 11-24-2007, 03:11 AM
newvances
I had only one sentry key (grey) and picked up a second sentry key this week from a locksmith. The new key is a little larger than the sentry key but it was 65 dollars vs 100 bucks plus tax which is what the dealer wanted.
The locksmith programmed the blank. He did not have to reprogram the vehicle..
My plan is to by another sentry key off of ebay and program it myself through the 2 key programming guide...
Current Jeeps: 04 TJ Rubicon, 04 GC Overland
Previous Jeeps: 07 JK Unltd Sahara, 04 TJ Rubicon, 03 TJ Sport, 02,94 GCLimited, 89 YJ Islander, 87 Grand Wagoneer
newvances is offline
post #15 of 22 Old 11-24-2007, 08:05 AM
2jhanna
this is one of cheapest places i have found. if you have 2 keys, any key shop can cut it and you can do the programing as per the manual.
http://www.abclockandkey.com/catalog/i34.html
jhanna
denton county, tx
2jhanna is offline
Would a duplicate key not work? dan523 JK Wrangler Technical Forum 42 03-23-2009 05:37 AM
97 Wrangler SE, lava liner, rear seat question, possible duplicate post...sorry mklap TJ Wrangler Technical Forum 8 05-30-2007 06:16 AM
Duplicate keys, $50 !?!?!? SavagePeters TJ Wrangler Technical Forum 23 01-20-2006 08:33 PM
