Dumb Question: Can u buy just coil springs for a 4 inch lifted Jeep? - JeepForum.com
post #1 of 13 Old 09-20-2010, 07:50 PM Thread Starter
Wrangler16
I have a really dumb question and really no where to find the answer unless someone here could help. I bought the 4 inch rough country lift kit stage ll and it rides really rough and was if there was any place where I could buy just better coil springs. Btw my jeep is a 99 jeep tj. Thanks for your help.
99 Jeep Tj, 4.0, Standard, lots done and lots planned
Wrangler16 is offline
post #2 of 13 Old 09-20-2010, 07:57 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Sure you can.
I've sold BDS ones to a kid that bought 4" but couldn't get in and had to back down to 3".
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #3 of 13 Old 09-20-2010, 08:02 PM
kelso1337
Buying springs separately shouldn't be a problem.
But if you're running RC then you have the 2.2 shocks correct? Which are not your Cadillac ride shocks.
I'm sure some guys will chime in about the shocks as a potential problem of yours.
I'd personally recommend OME shocks - expensive but worth it.
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
kelso1337 is offline
post #4 of 13 Old 09-20-2010, 08:09 PM Thread Starter
Wrangler16
Thanks guys! I actually found some Currie springs do u think they would be good to use? and i have the RC 8000 shocks i think so i will probably be upgrading them after the springs as well.
post #5 of 13 Old 09-20-2010, 08:49 PM
srlbotanical
IMO you need to ask what the spring rate is. I built my lift piece by piece with hand-me-downs from club members. The springs were the only new parts I purchased. When I checked around, I was surprised by how different the spring rates were from company to company. I went with 3" BDS springs in the end...
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #6 of 13 Old 09-21-2010, 12:48 AM
mudb8
want it rite or rite now?
mudb8's Avatar
start with a new set of shocks first, like Bilsteins or Rancho 9000xl's the coils are not the problem, I don't care what anyone say's, the RC 2.2's are harsh in comparison, come by and I'll prove it as I have four jeeps here with popular shocks including Rancho, OME, Bilstien, RE, and the RC's which are by far the roughest riding shock of the bunch.
if you must just get coils, Currie has progressive rate 4" springs which I think are comparable or the same as the AEV/Nth degree, Yes, I've driven on both.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #7 of 13 Old 02-24-2011, 06:28 PM
surfer1120
I have a RC 4" lift on my tj and i was wondering what springs i can i get to upgrade so when they settle it still is 4"
surfer1120 is offline
post #8 of 13 Old 12-29-2012, 01:00 AM
PC3
I have this exact question.
I have a 4" RC X-Series lift right now. Want to replace with Currie 4" coils and Bilstein 5100's. Will they fit?
I bought 5100's from Morris4x4center that are supposedly for a Jeep with a 4" SA kit...
Support Your Veterans
PC3 is offline
post #9 of 13 Old 12-29-2012, 04:24 AM
mukluk
Yes, you can swap out the coils and shocks while keeping the remaining parts of your lift.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 13 Old 12-29-2012, 07:03 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
of course, you can swap them. pay attention to compressed shock length and bumpstop extension requirements.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #11 of 13 Old 12-29-2012, 12:35 PM
Gary2
Maybe save yourself some money if you are staying at 4" . Get good shocks first . You will find the springs don't have as much to do with your ride as you think Control arm Joints have an effect , Track bar angle has an effect on the ride as does tire pressure ,load range. many things effect it .
Gary2 is offline
post #12 of 13 Old 12-29-2012, 04:24 PM
bolesr
What tire size and air pressure are you running?
bolesr is offline
post #13 of 13 Old 12-31-2012, 08:19 PM
PC3
Ive got Bilstein 5100s sitting here waiting to be installed with the Currie springs.
And I'm going to be running 35's, installing a 1.25 BL with a 1 inch MML.
PC3 is offline
4 inch , coil , lift , springs , suspension
new jeep! Turning problem on 5 inch lifted TJ Ethan79 TJ Wrangler Technical Forum 30 08-05-2010 09:37 PM
Need to 4 inch coil springs, front and rear pfifer TJ Wrangler Technical Forum 6 08-01-2009 03:31 PM
Coil Springs Question? 04TJSport TJ Wrangler Technical Forum 2 07-07-2009 06:47 AM
Coil Springs question AZTEX TJ Wrangler Technical Forum 13 04-24-2009 11:15 AM
is there shock rub on coil springs on lifted jeeps Slick101 TJ Wrangler Technical Forum 2 02-06-2008 03:28 PM
