Dumb, dumb question about mounting front license plate on stock bumper - JeepForum.com
post #1 of 19 Old 08-01-2006, 05:51 PM Thread Starter
flagstaffjeeper
Okay, here is probably the dumbest question I have ever posted on this forum!
How am I supposed to mount a front license plate on the stock bumper on my Unlimited Rubi?
Background: I bought this Jeep in Arizona where no front plate is required. I just moved to Texas, and have registered the vehicle here, and a front plate is required. Is the stock bumper supposed to have some threaded inserts so a plate can be mounted? If so, mine doesn't have them. I just have un-threaded holes in the bumper. I can't get back behind the bumper because of the tubular cross member that runs behind it, so I can't just use a couple of bolts and nuts.
Thanks in advance for having pity on me.
Current Jeep: 2006 Unlimited Rubicon
Previous Jeep: 1981 CJ7, 4.2L, Muncie SM465, Dana 300 t/c, Dana 30 Front, AMC 20 Rear
flagstaffjeeper is offline
post #2 of 19 Old 08-01-2006, 05:53 PM
yj_ryn
yj_ryn's Avatar
No one runs front plates in Texas, it is just a myth.
You just have to know the secret hand shake.
I have not had a front license plate of any cars / trucks / SUVs of mine since '96 and I have not had a problem.
Jeepless for now. . .but one day I hope to own another LJ
yj_ryn is offline
post #3 of 19 Old 08-01-2006, 05:55 PM
AustinJeep
AustinJeep's Avatar
Must be nice, I've been popped for it
2005 Lime Green Rubicon.
5" Clayton Longarm/Nth Degree/OME
35" Nitto Muds 17" Pro Comp wheels
AustinJeep is offline
post #4 of 19 Old 08-01-2006, 05:56 PM
RockRunner85
There are plastic peices that pop into the holes then you can use screws to attach the license plate. Stop by your dealer I'm sure they'll have some laying around. Worst case get some larger self tapping screws and just screw it into the metal holes.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #5 of 19 Old 08-01-2006, 05:59 PM
fundabug
fundabug's Avatar
Yippie!!! You get to remove the front bumper so you can get some nuts behind it! This really sucks, but you could just mount it on with some self tapping metal screws or drill some holes to the far right or left and mount it that way. I'm moving to the Austin area in about 2 months and was told I have to have a front plate also. I'm right there with ya brotha!
2004 Wrangler X 4.0 I6 Solar Yellow
fundabug is offline
post #6 of 19 Old 08-01-2006, 06:00 PM
thesherm
thesherm's Avatar
not a dumb question, i had my front plate in the windshield for 3 months before i figured out a solution. go to a hardware store and get two of those (if fget what they are called) screws that have bracket around em so that as you tighten the bracket flattens and widens. you'll need to pull up on the screw as you tighten it until it is almost all the way in. I am sure there is a more expensive solution from the stealership.
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #7 of 19 Old 08-01-2006, 07:09 PM
Bren Gun
Bren Gun's Avatar
Funny, my old stock bumper had a pair of threaded plastic insets that the bolts bolted into. Maybe you could find something like that at a hardware store... Or you could get a pair from me for 25 bucks plus shipping. As a bonus, they will come with a stock bumper attached to them.
'99 TJ, '03 KJ and a '53 CJ3B sitting in the barn waiting on a restoration... @
Gone, but never forgotten... 1973 DJ5C, 1964 CJ5, 1953 M38A1, 1971 Hurst Special Jeepster
Bren Gun is offline
post #8 of 19 Old 08-01-2006, 07:24 PM
tplochar
tplochar's Avatar
duct tape should work just fine
'05 TJ Willys Edition
2" RE BB
1.25" JKS BL
33x10.50 BFG A/T on 15x8 Blacked Out Cragars
A to Z Fabrication Rockers
K & N Intake
tplochar is offline
post #9 of 19 Old 08-01-2006, 07:26 PM
brgmgb
brgmgb's Avatar
If the dealer does not have the inserts, go to a real hardware store (where they sell nuts and bolts individually -- not in packages). They will have amber/yellow/orange boxes of different parts -- usually Jandorf products.
Find the box that has license plate screws and plastic inserts. There should be a variety of sizes. The "standard" size ones are too big, so you will be looking for some on the smaller side. You will probably have to use washers with the screws as the smaller inserts require smaller screws, with smaller heads. Even if you buy stainless steel screws, you will probably spend less than $1.
Bill Barge
'99 TJ Wrangler Sport
'02 Liberty Sport
'08 Grand Cherokee Laredo CRD
O|||||||O
brgmgb is offline
post #10 of 19 Old 08-01-2006, 07:28 PM
stevensinger
stevensinger's Avatar
thats right, if you can't duck it f.u.c.k. i.t. !!!!
stevensinger is offline
post #11 of 19 Old 08-02-2006, 03:51 PM
thinkwoods
Same problem moving from AZ to NY where they still run two plates as well as two ugly windshield stickers. Anyway I didn't wanna "mess up" the existing holes with oversize self-tapping screws, and plastic inserts required too small of a screw to hold the plates without washers, so I pulled the bumper off (6 bolts, no biggie), put a car store plastic frame on with nuts and bolts, then screwed the plate to the frame.
2004 Wrangler X, Solar Yellow
4.0L I6, 5 Speed, D30/D35, 3:73
thinkwoods is offline
post #12 of 19 Old 08-02-2006, 08:08 PM Thread Starter
flagstaffjeeper
Thanks for all the input. Here's how it has been resolved. Went by the stealership today to see if they would just give me some inserts. The service manager there didn't have a clue what to do, so he sent me back to the parts counter. The people back at the parts counter tried to sell me some kit for $41.00 that didn't even look like it would fit a Wrangler. I asked them (with much sarcasm!) if they thought it was a good idea to spend the $41.00 on what they showed me, and they actually agreed with me that it was pretty dumb. Ended up finding some moly bolts in a drawer in my kitchen and used those and a couple of locking washers to attach the plate to the bumper. I love southern engineering.
post #13 of 19 Old 08-02-2006, 08:18 PM
spittindurt
spittindurt's Avatar
make sure it doesnt hang down below the bumper or it will bend. you would think they could make a nice plate steel license plate but nooo has to be flimsy and bindy
mines in the stock location and now has the bottom inch or so bent back under the bumper.
2003 X With a little of this and a little of that.....
Check it out at
Real men run Super Swampers on their JEEP
Chrome won't getcha home!
spittindurt is offline
post #14 of 19 Old 08-02-2006, 08:48 PM
afiaccone
You should have not gone through the trouble!! I have lived in Texas all of my life and I have never had a front license plate on. Now to say I have never gotten pulled over for the lack of one would be lying but I have never gotten a ticket only a couple of warnings. Most don't want to do the paperwork and if they are that big of **!!& then they would pull over modded out Jeep anyways. As long as you are not riding dirty then it is a "Thank you officer " and away you go without the hideous thing on the front.
afiaccone is offline
post #15 of 19 Old 08-02-2006, 09:13 PM
yj_ryn
yj_ryn's Avatar
That is because you live in Austin.
yj_ryn is offline
06 Wrangler front license plate mounting McGough Wrangler General Discussion 5 08-13-2009 11:23 PM
Front license plate on stock bumper? pnzrdrgoon TJ Wrangler Technical Forum 6 04-15-2009 11:02 AM
Front License Plate Mounting shawnsix66 TJ Wrangler Technical Forum 13 11-13-2007 09:14 AM
Front License Plate Question (mounting) OffRoad98 TJ Wrangler Technical Forum 4 01-25-2005 10:24 AM
Question re: stock front License Plate Holder jnickers TJ Wrangler Technical Forum 4 12-27-2004 09:16 AM
