Dropping Tranny Need Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Dropping Tranny Need Help!
1987-1989 Jeep Wrangler Front Wheel Bearing & Hub Asse1990-1995 Jeep Wrangler Front Wheel Bearing & Hub AsseSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13
Unread 01-16-2010, 09:18 AM   #1
tealo951
Dropping the tranny out of my 97 6 cyl wrangler. need to know how many bolts are around the bell housing ( don't wanna lover the whole thing too much) and what type of bolts. someone said there are like, star bolts on the top? Need help. THANKS!
tealo951 is offline   Reply With Quote
Unread 01-17-2010, 03:44 AM   #2
wushaw
Rockin jeep
wushaw's Avatar
Two external torx on top, two on each side the go through the dowel pin holes with nuts on each side, two starter bolts and I belive three or four sheetmetal screws...one of em is right above the starter, the head is on the fwd side. Also the crank pos sensor on the l/h side upper bellhousing.
wushaw is offline   Reply With Quote
