dropped pitman arm - JeepForum.com
post #1 of 3 Old 10-02-2011, 02:13 PM Thread Starter
Droyer
dropped pitman arm
I have the 3" rustys lift that came with a dropped pitman arm and i had no issues. I recently installed the re1600 track bar (I know all about needing to be properly bump stopped) and now I have some bump-steer. So since I know it changed the geometry of my steering a bit I think installing a oem pitman arm would get my steering back were it needs to be?
Also I have some sagging in the front that needs correcting I measure 7" from center of the wheel to the fender in the rear and 5 1/2" from the center to the fender in the front so to level it out I can just purchase a 1 1/2" spacer and put it in front correct? this is with a full tank of gas and my hardtop on as well.
06' X d30/35 4.10(yukon) 31x10.5x15 goodyear Wrangler Duratracs, rusty's 3" lift(regret) RE superflex fixed lower ca's front/rear RE adjustable upper superflex ca's front/rear, smittybuilt src front bumper -stinger, xrc8 winch.
Droyer is offline
post #2 of 3 Old 10-02-2011, 02:56 PM
MayRoll
Yes, remove the DPA. The RE1600 TB does not come with a drop bracket so you'll need to use the OE pitman arm.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #3 of 3 Old 10-02-2011, 03:14 PM Thread Starter
Droyer
that's what i figured from reading various threads. Thank you MayRoll, Dose the 1.5" spacer sound right for leveling out the sag and rake of my front end?
Droyer is offline
Dropped pitman arm JGBrown YJ Wrangler Technical Forum 8 04-05-2007 10:40 PM
Do I need a dropped pitman arm? Roothog TJ Wrangler Technical Forum 4 03-20-2006 05:04 PM
When to Add a Dropped Pitman Arm? Highlander TJ Wrangler Technical Forum 5 02-28-2005 07:22 PM
Dropped Pitman arm or not? Tylenol7 TJ Wrangler Technical Forum 15 06-07-2004 12:07 PM
Dropped Pitman Arm Moxley YJ Wrangler Technical Forum 12 06-09-2003 09:27 PM
