Dropped Dash screw down defrost vent - JeepForum.com
post #1 of 12 Old 04-02-2014, 11:49 PM Thread Starter
bigwave
Last night while putting center dash part back over radio and climate controls I dropped the darn screw down the vent, stupid magnetic screwdriver gave me too much confidence. Is there any way without tearing dash apart to look for it and possibly get it back? I heard it rattle all the way down like a pinball. I fished around with a magnetic wand but did not catch anything. I don't think it can get to fan motor/blade but if I have to listen to it rattle I will go nuts. Any ideas? Thanks
bigwave is offline
post #2 of 12 Old 04-03-2014, 12:43 AM
MATT99TJ
Small magnet on a long string? Drop it in and let it bounce down and roll around. Hopefully it winds up next to the screw and you can fish it out.
MATT99TJ is offline
post #3 of 12 Old 04-03-2014, 06:54 AM Thread Starter
bigwave
I tried a magnet
That's a good thought, I did try a magnet but it was not on a string. I also have a fiber camera for looking in walls, pipes, etc. I fished it down there and could not see the darn thing.
bigwave is offline
post #4 of 12 Old 04-03-2014, 07:03 AM
dtperk
I was able to 'grab' a bran-new wheel bearing using a string and a Rare Earth (Neodime (sp?)) magnet down a 4" floor drain this way! Actually surprised me it worked!
Needless to say, the drain got a cover/grate that same evening....
(RIP) '82 CJ-7 | AMC 4.2 (.30 Over), T-4 / D300 | D30 Front - LockRight, AMC20 Rear - ARB, Moser Axles / 4.10s | York Air Setup - 2.5 Gal Reserve, QD's Frt/Rr | 2.5" SUA, 1.5" Shackle & .75" Body | 4WDH Glass Tub, Fenders & Hood | Stainless all the way around | 33" BFG MTs
dtperk is offline
post #5 of 12 Old 04-03-2014, 07:09 AM
-jb-
I wouldn't worry about it unless you fish a magnet or take the box out and take it apart.
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
post #6 of 12 Old 04-03-2014, 05:08 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Neodymium...
http://en.wikipedia.org/wiki/Neodymium_magnet
Knuckelhead is offline
post #7 of 12 Old 04-03-2014, 05:15 PM
Toby36
I would leave it and see if it even rattles first. Maybe try turning the control knobs to all positions and see if u can get it to drop to the bottom then see if you can stick something through the floor vents to get it
Toby36 is offline
post #8 of 12 Old 04-04-2014, 08:27 AM Thread Starter
bigwave
I think I now have a bigger problem, I can't hear the door move anymore that changes between inside and outside air. I'm wondering if the dam thing has lodged in there some how. I've looked for a diagram showing where that door is and if there is a easy way to access it. But, I can't seem to find anything showing me this info.
bigwave is offline
post #9 of 12 Old 04-04-2014, 08:38 AM
dtperk
As previously suggested, probably time to pull the air box assy out... Great time to swap heater core and do a blower fan upgrade, AND........ Get your screw back! (it's not a hard job), just time consuming and some contortion of your body under/behind the dash - - I'm with ya, put a head unit (el-cheap-o) in two weekends ago..... Reminded me...... I'm getting old
dtperk is offline
post #10 of 12 Old 04-04-2014, 08:38 AM
dtperk
Originally Posted by Knuckelhead View Post
Thank you!
dtperk is offline
post #11 of 12 Old 04-04-2014, 09:11 AM
Toby36
This might sound like a stupid question but is the vehicle on while u are trying to turn the flappers. If i remember correctly all the doors hang down so i dont think a little screw would jam them
Toby36 is offline
post #12 of 12 Old 04-04-2014, 09:21 AM Thread Starter
bigwave
ignition is on
Yes, ignition is on. I'm going to get it back together, hopefully, this weekend.
bigwave is offline
