Driveshaft Vibration worse after 4 in lift - JeepForum.com
post #1 of 26 Old 03-26-2010, 12:05 AM Thread Starter
jeepjeepjeep
I have an 05 TJ jeep wrangler that went from a 2 in lift to a 4 in rough country lift after the original 2 in lift I noticed a slight driveshaft vibration. Nothing major I lived with it for several months. I decided to step up to a 4 in lift. Once the lift was completed including the transfer case skid being dropped and the shifter extension was completed the vehicle was aligned. I found that I have a severe rear vibration.
I was told trying a Slip Yoke eliminator and CV driveshaft should solve the problem. I went this route after removing thr rear drive shaft and test driving no vibration at all. So after several more hundred invested. I now have the SYE and CV driveshaft installed I removed the skid case drop and the shifter extension since in the instructions for the lift it said neither were needed if an SYE and CV driveshaft were installed. The vibration is less but not to the point I could live with it. The vibration changes in sound and intensity depending on the speed I am going. I have also noticed a knocking sound going over speed bumps. Any thoughts or info would be much appreciated
jeepjeepjeep is offline
post #2 of 26 Old 03-26-2010, 12:52 AM
Alkaline
I'm no expert in this department, but the SYE should have done the trick I think. Is your pinion angle pretty agressive? Every jeep is different even with the same parts, so maybe a motor mount lift is the final piece of the vibe puzzle for you.
☠ ʎɐqə ɯoɹɟ pɹɐoqʎəʞ ɐ ʎnq ı əɯıʇ ʇsɐl əɥʇ sı sıɥʇ ☠
'98 TJ (toy), '91 XJ Briarwood(DD)
Alkaline is offline
post #3 of 26 Old 03-26-2010, 12:55 AM
Benderff
Benderff's Avatar
What is your pinion angle and what is your drive-shaft angle? How are your u-joints? Good chance the knocking is from your T-case shifter linkage.
Benderff is offline
post #4 of 26 Old 03-26-2010, 12:57 AM
BLATMAN
BLATMAN's Avatar
i just put the rc 4in lift on this past weekend. i did the tcase drop for now, there is a slight vibe but i didnt need the shifter extension either. it worked w/o it just fine. i also went from a 2in skyjacker b.b. Make sure u re-torqued everything and the new trac bar bracket is tight. it shouldnt vibe that bad, esp w the sye. good luck
02' TJ I64in. R.C. lift
adjustable R.C. Trac bar
R.C. steering stabilizer
33x12.5 General AT Grabbers
Pro Comp black steelies
[__]
OlllllO
I think you should put a CAI, Headers, new muffler.. some high flow cats... maybe one of those trail jammer chips.. oh and a tb spacer... can't forget that. You will be passing prius' in no time, unless their accel pedal is stuck..
BLATMAN is offline
post #5 of 26 Old 03-26-2010, 01:05 AM
BLATMAN
BLATMAN's Avatar
Jeep TJ Transfer Case Shifter Knocking TSB thats the link to fix the knocking...
[__]
OlllllO
BLATMAN is offline
post #6 of 26 Old 03-26-2010, 05:42 AM
rideraa
For vibes see below, I agree with the linkage and knocking possibility ^^^.
You may need adjustible control arms. The stock drive shaft arrangement wants the t case output and diff pinion parallel. Using the the SYE/CV set up the rear pinion and driveshaft should be a straight line with all the angle/direction change at the t case connection. Ussally you need adjustable control arms to get the SYE/CV geometry correct.
Go to Tom Woods drive shaft site for some diagrams of the above info.
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #7 of 26 Old 03-26-2010, 06:13 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I've done 4 of the RC 4" lifts on 5 speeds,6 speed and auto.On all of them,all vbes were completely gone with a MML and only a 1/2-3/4" t case drop.No SYE or adjustable CA's.
TheBoogieman is offline
post #8 of 26 Old 03-26-2010, 06:24 AM
little_Jeep
Click free for you.............
Did your lift kit include upper adjustable control arms? Between the upper adj control arms, the SYE, and possibly a MML, you shouldn't have any vibes.
little_Jeep is offline
post #9 of 26 Old 03-26-2010, 09:47 AM Thread Starter
jeepjeepjeep
Thank you for all of the great responses I have received
The 4 in rough country lift did not come with adjustable control arms. The sye and cv drive shaft were the suggested install after I installed the 4inlift and the vibrations got much worse.
I am just wondering if it would be best to correct the pinion angle first? I have not measured it but just eyeballing it I can see it is not a nice straight line as shown in the diagram .I believe there are shims to correct this? Not sure what they are called but in sifting through other members with the same problem they are commenting about needing 6 or 8 on the shims to match up with a 4 in lift
If I need a motor mount lift and adjustable control arms what size for the motor mount would be recommended to match up with a 4 in lift
So which angle of attack should I follow first? Pinion or MML
post #10 of 26 Old 03-26-2010, 09:58 AM
kolky
Another item to check is the track bar. Do you have an adjustable one? Make sure it is torqued correctly and that your axle is centered. When I bought my jeep it still had the stock trackbar with a 4" lift. When I replaced the dana 35 with an 8.8 and still used that trackbar it caused my axle to be pulled about a 1/4" to the passenger side and that caused a lot of vibration.
Yellow Jeep Club #1224
kolky is offline
post #11 of 26 Old 03-26-2010, 10:03 AM
blubaru2002
All jeeps are different.
With that said: You still need to fix your pinion angles. The Double Cardan DS and SYE aren't doing what they were meant to do unless you get your angles correct.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is online now
post #12 of 26 Old 03-26-2010, 10:04 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
You have an SYE, therefore you need to adjust your pinion angle with adjustable control arms. A MML may or may not help, it depends what your pinion angle currently is. The MML will only change the output shaft angle, NOT the pinion angle. The reason you do a SYE/CV is so the driveshaft can tolerate more severe output shaft angles, after you align the pinion angle.
Read this: http://www.jeepforum.com/forum/f9/wh...ml#post8636577
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #13 of 26 Old 03-26-2010, 10:08 AM
shawn1980
subscribed
green jeep club member #122
shawn1980 is offline
post #14 of 26 Old 03-26-2010, 10:30 AM
Benderff
Benderff's Avatar
A set of adjustable upper control arms are needed to adjust the pinion angle. You could do it with lower adjustable, but since you need to buy some uppers will be cheaper. You have done most of the work, but you have to set the pinion angle correctly to see the result you want. Once you do that you will be way happier with what you did vs. going the MML route.
Pinion Angle Alignment - 1
Benderff is offline
post #15 of 26 Old 03-26-2010, 10:37 AM
sbninja
sbninja's Avatar
As posted above, you need to get some rear upper adjustable control arms and adjust your rear pinion angle - as in the picture above. The MML Is used when doing a body lift, it also helps with driveline angle. The MML alone, will not cure your driveline vibration issues.
2004 Jeep Wrangler Sport - Black
WARN steering box skid,Nth degree Oil pan skid
RE 3.5" - M.O.R.E. 1" BL - M.O.R.E. 1" MML
15x8 Tech1 Rock Crawlers (4.5" BS)
35"x12.50x15 Dunlop Radial Mud Rovers
Aussie locked 30/ Ultimate 35 kit w/detroit
Black Jeep Club v2.0 Member #49
sbninja is offline
Driveshaft vibration with 1.75" spacer lift??? JhnBrackett TJ Wrangler Technical Forum 4 08-17-2010 09:55 AM
Bad vibration thats getting worse. no lift TJ04BLACK TJ Wrangler Technical Forum 10 12-28-2009 01:34 PM
Worse vibration after installing SYE and driveshaft!! kmo0189 YJ Wrangler Technical Forum 4 10-24-2006 07:57 PM
driveshaft vibration vespucci YJ Wrangler Technical Forum 2 10-14-2006 10:18 PM
Vibration fix: CV driveshaft w/o SYE? jcteel TJ Wrangler Technical Forum 5 03-30-2003 06:13 AM
