Quantcast Driveshaft U-Joints? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Driveshaft U-Joints?
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 11-23-2002, 12:19 PM   #1
Phantom5oh
I'm trying to replace the U-Joints on my front driveshaft. Is the rear double U-Joint replaceable? I've been told its a CV (Constant Velocity) joint. This type of CV is really only a double U-Joint, so I'm thinking it can be replaced the same was as a normal U-Joint. Can it or do I need to replace the whole driveshaft.
I have it all apart today, but I need the Jeep for tonight. The local parts store has Jeep U-Joints in stock so I am asking if I can replace them, or do I need to get a new driveshaft? If I need to replace the whole driveshaft I'll have to put it back together the way it is until I can get the new shaft.
I have a 98 Sahara. Any help would be great!
Phantom5oh is offline   Reply With Quote
Old 11-23-2002, 04:32 PM   #2
Devious
Hobo
Devious's Avatar
1996 YJ Wrangler
No, you don't need a new driveshaft, just replace them like the rest.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline   Reply With Quote
Old 11-24-2002, 07:54 AM   #3
K9JEEP
Registered Abuser
There's some truth in what you heard, but it was interpreted wrong. The Front DS U-Joints are Non-serviceable units. They cannot be greased periodically like other U-joints on your Jeep, they run dry and fall apart with time. However, they are replaceable, I forget the actual number used. If possible, ask the counter for a serviceable U-joints.
HTH
K9Jeep
Http://www.dso4x4.com
K9JEEP is offline   Reply With Quote
Old 11-24-2002, 10:35 AM   #4
Phantom5oh
The AutoZone near my house has the U-Joints in stock, they even have the ones with grease fittings. They are a little more expensive, but thats what you think I should get?
Old 11-24-2002, 04:53 PM   #5
igofshn
Locked @ both ends
igofshn's Avatar
They are the same u joints as the rear. Actually pretty easy to replace.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Old 11-25-2002, 08:47 AM   #6
Phantom5oh
I tried it on Saturday, but my bench vise doesn't open quite far enough to press them out. Any suggestions?
I need to have my front wheel U-Joints done, so I'm thinking I might just have it done.
Glock Forum
