driveshaft question?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > driveshaft question??
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 11-14-2005, 07:55 PM   #1
coorsmgood
2010 JK Wrangler
ok I just got my cv driveshaft and sye installed....when taking off it all feels good!
but....by the time I got up to speed on the interstate it was giving off vibes..
not vibes like before my sye which were more loose vibes....now its like a real strong tight feeling vibe?(hope that makes sense?)
what Im wondering is about the way the driveshaft is balanced...I dont see any washers welded on or anything and I think it was not balanced?is there any way it could be balanced if there are no weights welded on it?and does this sound like my problem with the tight feeling vibes?
the angle looks good ..if any bit off the pinion may be a touch lower wich is suposed to be good anyway..
my main question is..is there anyway my shaft has been balanced if there is no weights on it?
2010 4 door wrangler stock for now in burnt orange longhorns style!!
coorsmgood is offline   Reply With Quote
Unread 11-14-2005, 08:28 PM   #2
coorsmgood
2010 JK Wrangler
is it possible??..sorry just want to get this fixed in the morning and dont know where to start?
Unread 11-14-2005, 08:41 PM   #3
Stu Olson
Stu Olson's Avatar
Without having it checked, I don't see how anyone could say yes or no.
If it was balanced and it was not out of balance, then there would be no weights welded on.
If it was not balanced, there still would be no weights welded on.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
