Driver's side tie-rod flip on Currie HD Steering
#16 | ||
Straight Up Fool!
I made a drop bracket for the track bar, hell I had to modify the track bar. I honestly think I need to drop it some more. Think of the whole thing being reversed, the tie rod is still behind the drag link.
![]() Check out the last five or so posts in my build thread (linked in my sig...)
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#17 |
want it rite or rite now?
the track bar/position and bumptops need to be considered before jumping into the flip, it won't work with currie's new hd track bar, unless you don't care if they run into each other... then be particular of the position of the adjustment buckles.
just an example of a relocated re track bar via a clayton style frame mount... which is sitting on 2" bumpstops with the springs removed, obviously they can't pass by one another. ![]() this one is a currie track bar sitting on 2" bumpstops with currie steering links, stock length JKS adjustable CA's. ![]()
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#18 |
Im gonna bring this topic back up.
Mud, will my trackbar hit my tie rod if im running a stock trackbar on 2.5" of lift? Im considering doing this mod, but I dont want any interference. |
#19 |
bump for my original question, and one more
Will I experience a dead spot from this mod? I feel like I shouldn't since your not changing your draglink location, therefore leaving the trackbar and draglink on the same plane as stock, but when I brought this mod up amongst a few buddies one said that I will get bumpsteer... this didn't make sense to me. I also found a write-up where someone flipped a v8zj Tie-rod over the knuckle and also 180* from its original mounting location. Since the v8zj rod has a bend in it the swaybar mount did not have to be relocated. • View topic - Partial Tie Rod Flip good idea or bad idea? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
