Quantcast Driver's Side Mirror Glass Replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Driver's Side Mirror Glass Replacement
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 12-03-2008, 06:44 PM   #1
kypd114
Hey,
I was curious if anyone knew how to swap out a broken side view mirror glass for glass off a junkyard mirror i picked up. My jeep had a broken driver's side mirror (cracked) and I bought a mirror from a junkyard off a same year wrangler. Problem is, the new mirror from the junkyard's hardware is a bit rough. I basically don't want to have a glass company put a generic glass in there because I like the jeep stenciling at the top of it. Anyone done this before? How-to's would be appreciated.
Thanks
kypd114 is offline   Reply With Quote
Old 12-03-2008, 06:51 PM   #2
MCDavis
There should be some kind of rubber gasket that holds it in. Pry it out, put the gasket back on the new mirror, re-install. It's probably also glue in, so the existing mirror may have to be broken to get it out. The new one will need more glue/caulk/whatever to cushion it and hold it in place.
If there's not a gasket, post a picture I can look at. I've done this before, just not on a Jeep and I think my mirror is different from yours.
MCDavis is offline   Reply With Quote
Old 12-03-2008, 06:55 PM   #3
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
Duct tape?
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Glock Forum
