Driveline Vibration Question - Page 2 - JeepForum.com
post #16 of 22 Old 09-19-2010, 09:22 PM
thirdeye
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #17 of 22 Old 09-19-2010, 11:44 PM
2006_Sport
Ive been on vibes since last october. They were really bad when I first lifted now they are very minor since the MML i put in...ive had no problems yet, just saving up for that SYE.
2006_Sport is offline
post #18 of 22 Old 09-20-2010, 09:23 AM
IslandTJ
Are you regularly checking on your rear pinion seal and u joints? I'm saving up for a SYE, DC shaft and upper rear adjustable CAs too. I too have a MML and that was sufficient to eliminate my vibes after my 2" suspension lift. Unfortunately the vibes returned after I installed my UCF transfer case skid. I was able to remove the vibes once more, by installing a transfer case spacer/drop.
If you're still getting some minor vibes, I recommend dropping your transfer case a washer at a time until they are completely gone. This will save your u joints and pinion seal from a premature failure.
Now Jeeping in Oregon
IslandTJ is offline
post #19 of 22 Old 09-20-2010, 11:01 AM
2006_Sport
Oh yeah. I keep a set of 2 spare u joints in my glove box too I'm always checking them after every day where I'm driving a lot. I'll try the washer thing, gotta keep my frame nutserts from spinning first so I can get the skid down.
post #20 of 22 Old 09-20-2010, 01:24 PM
thirdeye
SYE/CV shaft is the best way to spend your money ever.
thirdeye is offline
post #21 of 22 Old 09-20-2010, 03:04 PM
IslandTJ
Don't forget the $$$ hardware required to adjust your pinion angle too .
IslandTJ is offline
post #22 of 22 Old 09-20-2010, 05:18 PM
thirdeye
It was kinda weird; when i put mine in, I had ordered upper adj. CAs and an angled track bar bracket, but after i put the SYE & shaft in (I was still waiting on the CAs to be delivered) the angle was perfect with the stock CAs
thirdeye is offline
driveline vibes , driveline vibrations , skyjacker , transfer case , transfer case drop
driveline vibration zone1090 TJ Wrangler Technical Forum 4 01-20-2011 11:26 AM
Bad Vibration at or above 45 mph, not driveline. jeeptj03 TJ Wrangler Technical Forum 15 07-19-2010 08:56 PM
Driveline vibration jeepdog5 YJ Wrangler Technical Forum 3 05-06-2010 12:10 AM
Driveline Vibration Allstar YJ Wrangler Technical Forum 6 08-10-2007 07:48 PM
Driveline Vibration AFTER MML nfunlimited TJ Wrangler Technical Forum 10 05-31-2007 02:14 PM
