driveline vibration - JeepForum.com
post #1 of 5 Old 07-25-2009, 04:05 PM Thread Starter
zone1090
driveline vibration
02 jeepTJ 2.5, auto
Dana 30 4.88 aussie locker, dana 44 4.88 detroit tru trac,
Brand new driveshafts
belly up, sye ,nw chain, new planatary, bearings ok
Vibrates at 30,65 pulltransfer into 4wd high vibration quits untill you let off or continue to accelerate. I mean the truck drive completly smooth them suddenly starts vibrating like you fliprf a switch. Help!!
John
zone1090 is offline
post #2 of 5 Old 07-25-2009, 04:09 PM
Imped
Imped's Avatar
OK, so you're saying you get vibes at 30 and 65 only when in 2 or 4hi? Or only in 4hi? Write a little clearer please.
OlllllllO
IndyORV
Imped is offline
post #3 of 5 Old 07-25-2009, 04:10 PM
Mini-Me26
Have you had the tires balanced?
Mini-Me26 is offline
post #4 of 5 Old 07-25-2009, 06:44 PM Thread Starter
zone1090
vibrate at 30 to 40, eases off the comes back at 50-65 then smooths out. If i pull it into 4wd hi it drives perfect through all the speed ranges. But as you excellerate or dcellerate the vibrations comes back like you fliped a switch.
It can't be tires or pionion angle because it smooths out when in 4wd hi. Remember I put it 4wd hi and then put it back in 2wd all in one motion.
zone1090 is offline
post #5 of 5 Old 01-20-2011, 11:26 AM
yellowjesus
what was the solution i feel like i am having the same issue
yellowjesus is offline
Driveline Vibration ROCKOMORI TJ Wrangler Technical Forum 2 02-26-2009 11:48 AM
Driveline vibration after BB Badawee TJ Wrangler Technical Forum 10 02-23-2008 03:03 PM
driveline vibration rickr YJ Wrangler Technical Forum 2 11-14-2004 10:54 PM
driveline vibration. got_rocks YJ Wrangler Technical Forum 3 02-13-2004 03:45 PM
Driveline vibration. Blue_Bandit79 YJ Wrangler Technical Forum 2 06-10-2003 05:23 PM
