Drivebelt (serpentine) Length question - JeepForum.com
post #1 of 1 Old 09-30-2010, 05:07 PM Thread Starter
PDXTJ
Couple of things up front. I have been lurking awhile here and have seen how "dumb" questions get treated so I will do my best not to irritate anyone.
Second.... Yes I did search the forum for answers.
And last... I know my profile shows that I just joined but this is my 4th Jeep but my first TJ. Just got this 2000 TJ sport used a few weeks ago. Aside from a K&N air filter there appear to be no mods to the 4.0L engine.
The problem seemed simple: Squeaking drivebelt when cold. Better when hot. Either old belt or bad spring in the tensioner.
Tensioner could be moved a bit with my hand and not a breaker bar so I figured that was the problem.
I ordered a new tensioner and a new belt from rockauto.com. Figured I might as well change the belt while I am there.
Pulled off the old belt replaced the tensioner with no problem. But the new belt was new too short by about an inch. I had the tensioner fully depressed with a 1/2inch breaker bar. The routing is correct as well. (I checked several online diagrams and had taken a few pics ahead of time)
I checked several sites and the Gates Micro - V PN K060882 is listed each time as the correct belt. I called my local Mechanic and a local Baxter's Auto. They all agree that the PN K060882 is the correct belt for this engine with A/C.
The old belt is a Gates Micro- V K060900. I reinstalled the old belt and it fits fine, runs fine, no problems.
So the question - Is there something common or uncommon that the guru's here know about that would make the correct belt not fit? Is there any common mod that perhaps the previous owner performed that would require this longer belt. ( I swear I went over the front of that engine several times and I do not think there is anything but stock equipment. I even poked around in other areas and found a block heater. That was cool to find but not helpful for the current problem)
Clearly the jeep runs and works fine so this is not urgent. Thanks for any thoughts / comments
If someone else finds an answer by searching this site all I can say is, "my bad" and "Go easy on me"
Thanks - Scott
PDXTJ is offline
serpentine belt
Serpentine belt length? Dragon_1973 TJ Wrangler Technical Forum 9 01-13-2013 01:36 PM
97 tj serpentine belt length genisis88 TJ Wrangler Technical Forum 1 03-21-2010 06:13 PM
Serpentine question FlyinCedar YJ Wrangler Technical Forum 4 11-11-2009 10:15 AM
What length serpentine belt?? mall0y YJ Wrangler Technical Forum 3 02-12-2008 07:46 PM
4.2 YJ Serpentine Question ZG YJ YJ Wrangler Technical Forum 20 08-17-2006 11:18 PM
