drive shaft spider journal!!!! - JeepForum.com
post #1 of 14 Old 03-25-2009, 01:57 AM Thread Starter
Teddy
Hey guys today i wanted to install my stock wrangler"x" drive shaft to a rubi d44 but the spider journal is loose it move around.. and the rubi drive shaft wont bolt to my "X" t-case any idead what to do i have a budget of 50 MAX if i have to buy anything
Teddy is offline
post #2 of 14 Old 03-25-2009, 03:09 AM
69injun
69injun's Avatar
The What???
Kevin
97 TJ on 37's and 69 Firebird Convertable on blocks
69injun is offline
post #3 of 14 Old 03-25-2009, 03:22 AM Thread Starter
Teddy
spider journal the little + the connects the shaft to the yolk i think its called spicer? i have no idea
Teddy is offline
post #4 of 14 Old 03-25-2009, 03:31 AM
CSCmrwizard
1982 CJ5
the u-joint
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
post #5 of 14 Old 03-25-2009, 03:33 AM Thread Starter
Teddy
YES thank you!!!
Teddy is offline
post #6 of 14 Old 03-25-2009, 03:42 AM
69injun
69injun's Avatar
Yup the U-Joints are different and wont work. That is why without the Rubi transfer case you need a custom Driveshaft. Or you may be able to get a conversion U-joint but I don't know.
Kevin
69injun is offline
post #7 of 14 Old 03-25-2009, 08:33 AM
otisdog
2008 WK
I think this is what you need. You can call Northridge to be sure.
Your driveshaft uses 1310 ujoints and I think the Rubi yoke needs the 1330.
http://northridge4x4.com/proddetail.php?prod=RE-1823
Jim
MORE:
http://completeoffroad.com/i-123005-...onversion.html
08 Grand Cherokee Overland
otisdog is offline
post #8 of 14 Old 03-25-2009, 12:45 PM Thread Starter
Teddy
Jim
MORE:
Thanks a lot Jim ordered a pair and see what happens =)
Teddy is offline
post #9 of 14 Old 03-25-2009, 06:10 PM
69injun
69injun's Avatar
Yup that is what I was thinking. Good job Jim. See Teddy you at least know enough to come to the right place to ask questions. Even if you do get bashed about a bit. Could be much worse, you could be going to Pirate 4x4!!
Kevin
69injun is offline
post #10 of 14 Old 03-25-2009, 07:03 PM Thread Starter
Teddy
hehe i never been to pirate hopefully never will have too!!
today i took my car to a local shop and they owner said if you continue to drive it with this setup and how you installed all this you will be breaking things left and right and my front dana is bent so that has to be tossed or if any one wants to buy it. and im also forced to sell my rear 44!!! i hate my life price check one a bent front dana44 and a rear 44(disk brakes) and my build comes to a hault until i sell the rubi cab/w.e left and figure something else out
Teddy is offline
post #11 of 14 Old 03-26-2009, 05:57 PM
69injun
69injun's Avatar
Teddy a diff can be straightend you know. I know that most factory ones arent perfectly straight anyway. But alot of good rear end shops can true a axle housing. I know most muscle car guys get this checked and fixed before building a rear for a high power car. Just something to check into.
Kevin
69injun is offline
post #12 of 14 Old 03-26-2009, 06:52 PM Thread Starter
Teddy
Well i never knew that..you have a idea about how much it would run me? like a estimate
Teddy is offline
post #13 of 14 Old 03-26-2009, 08:52 PM
69injun
69injun's Avatar
Sorry can't help you there. I have never had to have it done Yet (knock on wood) But you should be able to call around and find someplace that can do it and get a estimate. Just a thought
Kevin
69injun is offline
post #14 of 14 Old 03-26-2009, 09:53 PM Thread Starter
Teddy
will do tomorrow after court....god be with what a way to kick off the weekend
Teddy is offline
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
DANA44 can't remove diff ls spider gears shaft pin imoafa TJ Wrangler Technical Forum 10 09-28-2009 12:59 PM
Can't get my drive shaft off of the output shaft, any tips/tricks? Dmcastino TJ Wrangler Technical Forum 6 07-23-2009 06:02 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
Spider gear/mate shaft removal rkroel YJ Wrangler Technical Forum 6 09-01-2007 05:21 AM
