Drive line vibration solutions - JeepForum.com
post #1 of 5 Old 07-21-2010, 10:11 PM Thread Starter
WillieP23
So I have a 1998 2.5L TJ. I just installed a RC 2.5" suspension lift which came with 1" pucks to mount to the diff skid plate. So I installed the spacers so that i would not have to deal with any vibes. However since the pucks did their job and reduced the drive line angle which of course lowers the transmission and in turn made 2nd, 4th, and reverse gear alot harder to shift into and keep it there.
So my question is what should i do if anything. I'm look ing at a couple options.
1. Leave the spacers and just deal with some of my gears poping out or not going in very easily when i drive around town.
2. Leave the spacers and get the shifting linkage bent to make it easier to shift. (because the only way to adjust the shifting linakge is to bend it right? I just cant loosen a screw and move a rod or something like that sorrect?)
3. Remove the spacers and install a motor mount lift like the JKS 1" bmm. That should fix my shifting issue and at the same time keep my drive line angle correct. However I am not running a body lift and not sure how easy they are to install with out a bl on and also, is there any thing else that I would need to do after installing the mm.
4. Remove the spacers and install an sye kit. This would defently solve my driveline angle and my most expensive option. But I don't know if this is complete overkill because I never plan on lifting my heep more than it is because I only want to run 32's because of my 4 banger.
So alot of options and Im pretty new to the whole drive line geometry thing so any advice would be helpful. Any knew options would also be helpful.
Thanks alot
WillieP23 is offline
post #2 of 5 Old 07-21-2010, 10:22 PM
dcope17
Thanks alot
This option will be like adding 34s with your tc drop when it comes to your belly clearance by getting rid of the 1" drop.
You can also grind out the tub a little where the stick is hitting the tub...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #3 of 5 Old 07-24-2010, 09:51 PM Thread Starter
WillieP23
thanks for the advice man.. I'll probly go with the sye just curious if any of the other cheaper solutions would fix my problem for sure. Any one else got anything to add?
post #4 of 5 Old 07-24-2010, 10:01 PM
lawson1273
Its probably not hitting your tub. I did the drop and later removed it because of the same issue you had. I just added a few washer three to be exact to drop it just enough so I didn't get vibes. I also replaced the rubber shifter boot with an after market pleather one I got at auto zone which freed up about an 1-1 1/2 of space for shifting. I believe the boot was like 10 bucks. Its one of the universal ones. Worth a try it worked for me.
lawson1273 is offline
post #5 of 5 Old 07-25-2010, 02:37 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Get the MML from RC and take the spacers out.All you need to do is move the fan shroud 1"(no BL) by drilling new holes or using brackets that come with BL kits.I have the brackets if you want them(free).
TheBoogieman is offline
vibrations , drive line , tj , wrangler , sye , t-case , drop , solution , advice
Drive line vibration... JeepinVet TJ Wrangler Technical Forum 12 05-22-2010 03:09 PM
Front drive line vibration 97tjeep TJ Wrangler Technical Forum 5 01-29-2010 07:18 PM
feels like drive line vibration..... lonepunker YJ Wrangler Technical Forum 12 12-09-2009 05:36 PM
rubicon drive line vibration ncopp TJ Wrangler Technical Forum 13 08-31-2009 03:52 PM
Prevent drive-line vibration timekpr TJ Wrangler Technical Forum 6 04-11-2004 11:36 AM
