Drip drip it goes - JeepForum.com
post #1 of 5 Old 12-10-2003, 09:56 AM Thread Starter
tjslawny
Drip drip it goes
Been parking my '99 Jeep Sport in my garage lately, and notice a quite a few drips on the floor. I put down some newspaper to judge where its dripping from....seems to be coming for somewhere between the back of the engine oil pan and the front of the manual tranny....any ideas to what this could be? a leaky gasket on the oil pan perhaps? What are we talking in terms of getting this fixed $$$?
Thanks for the help in advance.....jeep on
tjslawny is offline
post #2 of 5 Old 12-10-2003, 10:28 AM
Scootr
Scootr's Avatar
Mine did the same thing,dealer said they put some dye in it to see if it leaking or if it's just fluid from the last change.They said they didn't see any dye. My oil level hasn't gone down so who knows what it might be
Lead, Follow or get outta the way!
2007 JK "X" 2dr Jeep Green,auto, 4.10's, 6 disc Infinity system with sub, 32's w/Pro Comp Xtreme Alloy Series 8179 wheels, Smittybilt SRC side bars,Sirius 1 unit, Magellan Maestro 3100 GPS . Former Jeeps...02 and 05 TJ Sports
SEMPER FI !
Scootr is offline
post #3 of 5 Old 12-10-2003, 11:32 AM
macb
macb's Avatar
rear main seal is likely if it is oil.
you need to drop the pan to get at it and it is a 2 peice so it is easy to replace once you can get at it. but it is a PITA to get at.
had to disconnect the exhaust to get enough leeway to drop the pan.
New seal was like $25 and the oil pan gasket is a metal 'lifetime' one unless you jack it up.
Since I had the pan down I had a friend weld a peice of 1/4 to it so I don't smash it up on the trail (it was a little tricky since the pan is pretty thin so make sure to water test it at least before installing it...) it makes the cheapest skid plate available...and is good insurance. btw, if you do that - have the front of the plate turned up like a ramp and don't forget to have the rear of the plate notched for the drain.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #4 of 5 Old 12-11-2003, 09:22 AM
teesea
teesea's Avatar
What exactly did you do to replace this? You said a rear main seal but only dropped the oil pan. I thought the rear main was between the enging and tranny?
teesea is offline
post #5 of 5 Old 12-11-2003, 01:03 PM
macb
macb's Avatar
the seal is a 2 peice, when you drop the pan you will see it at the back end - you can
pull off the lower peice and then push the upper peice out.
Bob Supplee:
or (405) 799-8977
macb is offline
Mysterious Drip xjGeoff18 TJ Wrangler Technical Forum 2 08-26-2009 06:25 AM
drip drip cake TJ Wrangler Technical Forum 2 05-29-2008 06:56 PM
Drip, Drip, Drip... kevin A Whitler YJ Wrangler Technical Forum 6 05-19-2008 08:01 PM
oil drip Mike Davis YJ Wrangler Technical Forum 7 12-24-2006 10:39 AM
A/C drip drew622 TJ Wrangler Technical Forum 2 07-29-2003 07:28 AM
