Quantcast Drilling holes on your hard top - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Drilling holes on your hard top
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 01-25-2007, 06:40 PM   #1
rpx13
Has anyone drilled holes in their hard top to install towers for a ski rack? I tried searching for this topic, but not much info came back. I know that there might be problems with water leaking when it rains and sagging in terms of the hard tops' ability to hold up to 4 skis/snowboards. So, I am wondering if anyone has done this and if so how were your experiences with it? If anyone knows of a thread that would be helpful too. Thanks!
rpx13 is offline   Reply With Quote
Old 01-25-2007, 06:42 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
once you drill and add the bolts use some RTV to seal the hole to prevent leaks, as for sagging as long as mounts are near outer edges and the small weight of skis id say your fine
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 01-25-2007, 06:53 PM   #3
rpx13
I dont think the actual mod would be that difficult, and I agree with the mounts being as spread out as much as possible. I was actually more worried about the sagging (or in this case flexing) when driving and the wind is hitting the skis/snowboards which causes the hard top to flex outwards.
Old 01-25-2007, 07:12 PM   #4
Steelz19
I put a rotating light bar which was about 4lbs on my old hard top...on the inside i used a piece of steel flat stock for a little more support worked fine
2000 TJ with 32" BFG's on soft 8's, warn winch w/ custom bumper, 2" Fabtech BB.... more to come (hopefully)
Steelz19 is offline   Reply With Quote
Old 01-25-2007, 07:53 PM   #5
tjwhlr00
Im running a yakima rack on my hardtop. Came with tracks that mounted directly to the top and the towers and crossbar attatch quickly with an allen wrench. Used silicone to seal the 4 holes on either side of the top and haven't had any problems with it. Its even really sturdy, ran a XC and freeride bike on top down the highway with no problems.
tjwhlr00 is offline   Reply With Quote
Old 01-25-2007, 07:56 PM   #6
surfcaster
Which yakima set/system are you using? I want to do the same thing for fishing rods.
surfcaster is offline   Reply With Quote
Old 01-25-2007, 08:28 PM   #7
tjwhlr00
mmm... im not too sure the exact one, its actually designed for tops (fiberglass and aluminum) both on jeeps and bed covers on trucks. i'll check out the yakima website and see if i can get some product numbers or something.
here it is http://www.yakima.com/Product.aspx?id=24
they come about 8 inches too long but i just cut them down.. worked great.
Old 01-25-2007, 09:22 PM   #8
g-dawg
I'm using the Yakima tracks running fore and aft on each side. Then the control towers ride in them. Totally adjustable and the control towers just pop off after you unlock them. Also, I believe the tracks help beef up the top. I carry two large sea kayaks on top of my 2004 Sahara and have had no problems. I installed the two tracks just like Yakima instructed and they work perfect. No leaks in 3 years.
g-dawg is offline   Reply With Quote
Old 01-26-2007, 12:38 PM   #9
rpx13
these are just the tracks right? Looks good. If you have any pics of ur setup try and post one up. Thanks!
Old 01-26-2007, 01:29 PM   #10
CRJeepin
My .02 - having drilled thru fiberglass a few times before I'd advise putting some duct tape (or similar thick tape) over where you start the hole, to keep it from splintering. Never drilled into my hard top but have repaired it
CRJeepin is offline   Reply With Quote
Old 01-26-2007, 01:45 PM   #11
Bigbob
Bigbob's Avatar
Go to the hardware store and get some fender washers to use on both sides. Much them with silicon and bolt them a little better than finger tight to both sides of where you drilled. This will strenghten the area alot.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 01-27-2007, 10:42 AM   #12
tjwhlr00
http://rides.webshots.com/photo/1541634297084231740KAIjuW?vhost=rides
i duno if that worked. But theres an old picture with the rack on i run two bike mounts but have a ski rack that i run when i go to boone
Old 01-29-2007, 11:22 AM   #13
rpx13
sweet...exactly what I had in mind...
Old 01-29-2007, 01:12 PM   #14
SJ5.9
I've had the same set up for a couple years. Mounted 2 XC mountain bikes or snowboards on many trips. Rain/snow - no leaks. 4 boards should be no problem. I like the bonus of removing the racks, towers, & cross bars when not in use. Takes about 5 minutes total - unlock, release tower latches, slide off.
Little bit of a howl with boards on top @ 70 mph & getting mtn bikes on top with 6 inches of lift & 35's is a b!*ch sometimes after a long ride, but overall I am happy with the set up.
02 Sahara 4.0 w/5 spd - 4.5 Rubicon Express Short Arm lift, 1" MML & BL, Rancho 9000's, SYE & Shaft, 35x12.5 BFG Mud Terrains, Thompson Classic Lock 15x8's, 4.56's w/ARB & Alloy USA Shafts, Warn Front & Rear Bumper w/tire carrier, Warn XD8000i, Toys by Troy Cage & skids, Big Daddy Off Road Rockers, Swayloc, Jeepers & Creepers Dual Battery, OBA, rock lights, more stuff, some junk, & stuff.
SJ5.9 is offline   Reply With Quote
Glock Forum
