Drilling holes in rollbar? Highlift mount.
| Truck-Lite's New LED Headlamp Series | NEW! Poison Spyder RockBrawler BFH Bumpers! | Poison Spyder BFH Rear Bumpers |
#1 | |
Had been looking at a number of highlift mounting options and just did not find anything I really liked. I want the jack inside and wondered if there is any reason I could not just mount it in back, to the rollbar, by drilling a hole on each side through the rollbar and attaching it with 7/16 or 1/2 in bolts, putting either the bolt through the rollbar and nutting it to keep it there and then sliding the jack over the bolts and nutting it on, or just putting the bolts through the jack, sliding rubber insulators over the bolt, putting the bolts through the rollbar and nutting them. It seems any "weakening" of the rollbar would be offset by the jack becoming a cross brace/stressed member so to speak. Any thoughts?
#2 |
forum supporter
Youcan use a couple of muffler clamps to mount it there, and you won't have to drill thru the cage.
#3 |
#4 |
I just thought the bolts would be alot easier and much more solid. I have seen the muffler clamp idea and was just wondering why we are making this more difficult than it needs to be? Plus I can drill throough the bolts for small padlocks. Plus I can remove the whole thing in seconds if I want to run without the jack.
#5 |
forum supporter
You can drill through the bars if you want. It won't weaken them. I just threw out the muffler clamp idea, in case you changed your mind about having it there.
#6 |
drillling the roll bar will seriously weaken it. if you must drill the bar you should sleeve it to regain strength
98 tj sahara re4.5sf,bfg 33 12.50mt d30arb/d44 detroit 456 gears bulletproof bumpers/tomken skids/tor roll cage warn 9000i |
#7 | |
Any hardware store should have them and are cheap. All you'll need is 2 longer carriage bolts to secure the jack to, 2 large washers, and 2 wing nuts. http://www.hooverfence.com/catalog/cpage2.htm |
#8 |
Running Secretly Amok!
Her's one thread I found,many more.http://www.jeepforum.com/forum/f46/high-lift-jack-mounting-location-229681/
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
