Drained wrong plug. Need help! - JeepForum.com
post #1 of 46 Old 07-24-2009, 03:10 PM Thread Starter
bradpenton
Just bought a 97 wrangler tj 2.5 lt. . probably did the last owner a favor.i chose to do it the hard way. i put the jeep in the garage and crawled underneath look at the transmission and drain the first plug i find. to my surprise about a gallon of fluid comes pouring out about the thickness of 30 weight or thinner like brake fluid but black. i think i drained the clutch fluid. what should i do. Please help. The Plug i drained was right behind the bell housing on the bottom of the tranny before the pan.
bradpenton is offline
post #2 of 46 Old 07-24-2009, 03:13 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Does it smell really bad?
Could be gear oil. What was the size of the plug?
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #3 of 46 Old 07-24-2009, 03:21 PM
RLD831
RLD831's Avatar
There is no way that you drained the clutch fluid unless you cut the line. The clutch plumbing isn't even routed along the bottom of the bellhousing. It goes from the engine bay to the driver side of the bellhousing about halfway down.
RLD831 is offline
post #4 of 46 Old 07-24-2009, 03:25 PM
jpony645
Sounds like you just drained the engine oil? Only thing I can think of that would hold that much black fluid.
jpony645 is offline
post #5 of 46 Old 07-24-2009, 03:28 PM
tjsahara1979
x2, Thats what I was thinking
Originally Posted by Dave Barry
There is a very fine line between "hobby" and "mental illness"
'01 TJ Sahara. 3" BDS lift, 1" PA BL, 33x12.50x15 Nokian Vatiiva M/Ts, Durango steering box, soft 8s, RE steering stabilizer, and one LOUD effin' train horn :)
Green Jeep Club Member #183
tjsahara1979 is offline
post #6 of 46 Old 07-24-2009, 03:33 PM
robncar
robncar's Avatar
Uh, either this is a joke or you're not giving the correct orientation of what you did.
If you pull the dipstick, does it have oil on it?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #7 of 46 Old 07-24-2009, 03:34 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I hope he knows the difference between an oil pan and a transmission.
http://www.4x4xplor.com/trannyservice.html
TheBoogieman is offline
post #8 of 46 Old 07-24-2009, 03:35 PM
03rubiconMG
behind the bell housing is the tranny fluid. if it was a 17mm alan wrench you drained the tranny fluid. if you did this then find the plug on the side of the transmission that the same nut fits.
If you used a 5/8s wrench then you drained the engine oil.
you did not drain clutch fluid.
at least thats what it is on the NV 3550 tranny and the 4.0
2003 white rubicon on 37s
03rubiconMG is offline
post #9 of 46 Old 07-24-2009, 03:43 PM
jpony645
If he did, he wouldn't be asking what that fluid is.
jpony645 is offline
post #10 of 46 Old 07-24-2009, 03:47 PM
TheBoogieman
Disturbed
My 6 year old nephew knows that.It's a sad,sad day on JF.
post #11 of 46 Old 07-24-2009, 03:49 PM
jpony645
Everyone has to learn. Some just go about it the hard way.
jpony645 is offline
post #12 of 46 Old 07-24-2009, 03:50 PM
03rubiconMG
find the next drain plug and take that out and let us know how much of what comes out of that one. then maybe we can narrow it down a little more. this seems like the start of a fun game. haha
post #13 of 46 Old 07-24-2009, 03:51 PM
Divinitous
Divinitous's Avatar
I'm not sure why you guys are playing with him here.
It's obvious that he emptied the blinker fluid reservoir.
-Ryan
post #14 of 46 Old 07-24-2009, 03:53 PM
blktjjp
Maybe the guy isn't a gearhead and is just learning. Everybody starts somewhere. I doubt from these responses he'll be back. Maybe more help, a little hospitality and less ridicule would be the way to go. Nice work.
blktjjp is offline
post #15 of 46 Old 07-24-2009, 03:54 PM
TheBoogieman
Disturbed
I thought it was the 710 fluid.
High idle after battery drained telkinsjr TJ Wrangler Technical Forum 3 12-18-2009 10:10 PM
drained battery randymack TJ Wrangler Technical Forum 1 09-23-2009 09:59 PM
Battery drained ~ now idles way too low??? SoTX Hunter TJ Wrangler Technical Forum 13 05-20-2008 08:41 PM
Drained battery, started, now dying?! ggrodregez TJ Wrangler Technical Forum 16 12-09-2007 08:44 PM
wrong spark plug or wrong engine? oldfrt47 YJ Wrangler Technical Forum 1 10-10-2003 05:45 AM
